Question about Tom Ford Clothing Accessories
Nose guard fell off
Optician couldn't repair
My nose bridge is falling off on 1 side of my Nike skylon ace ev 0525 003 prescription sunglasses can it be replaced? If so how much?
Take it to any optician shop Mary and they will fix it for you. The bridges on my reading glasses cost $5 to replace and takes 5 minutes.
Apr 03, 2016 | Nike Skylon Ace EV 0525 Sunglasses
One of the nose guards has gone missing. Where can I find a replacement?
Dear Slin,
I Would Just Buy A Cheap Brand Of Glasses That Has The Same Kind Of Nose Guards That You Want To Replace. Buy The Cheat Glasses And Replace The Nose Guard To Your Glasses :o)
I've Done This Many Times. And You'll Have An Extra Nose Guard.
Sep 10, 2011 | Coach Lafayette S510 Sunglasses
LOST THREAD..
Expensive brands like Oakley mostly give a warranty for their merchandise. So first look when you have bought the glasses, and if you have still the bill and a valid warranty. The best thing is to go to the optician where you have bought the glasses, and if this is not possible look for any other optician who is selling Oakley glasses. He can get you spare parts and repair the glasses if possible. If there is no warranty existing he also can give you an estimate of cost for the repair. Good Luck
May 21, 2011 | Oakley Juliet Sunglasses
Lense split exactly at center along the indent where the nose bridge is. Can this be replaced or repaired? What cost?
Did you buy these glasses recently and still have the bill? Was there a warranty? How did you get them damaged? Did you buy them at an optician? In this case bring them there and try to make a complaint. According to my experience a damage like that cannot be repaired, but if the damage has not been caused by impact like somebody stepping or sitting on them, and the glasses are quite new you may succeed in getting them replaced. Wish you all the best!
May 17, 2011 | Ed Hardy EHS 024 Sunglasses
Hello, I have Just Cavalli JC225 glasses. They were too tight and the arms were widened, to stop the glasses being pushed forward. Now they rest too heavily on my nose, causing red marks and...
There are a couple of things that can be done to fix this problem. One of the easiest solutions is to have the nose pads replaced with larger and/or softer nose pads. Alternatively, a saddle shaped nose pad can be helpful in distributing the weight across your nose. Most local optometrists should have nose pads available that they can change out for you.
Furthermore, if the nose pads are set at a bad angle they can dig into your nose also. Adding some curl to the end of the arms can bring the glasses closer to the face if they are sitting too low. If you are careful you can attempt some of these adjustments yourself.
Feb 25, 2011 | Roberto Cavalli Just Cavalli JC225 097...
I need two replacment nose bridge pads for a Kate Spade 135 EMME 1/S KADP. Where can I get them?
you can get the nose pads from any opticians, and they only cost a few pence each,
hope this helps
Feb 03, 2011 | kate spade Emme Sunglasses
Replace rubber on nose pieces
go to an opticians and it will only cost a few pence and they will replace them and fit them so they sit snug for you
hope this helps
Feb 01, 2011 | Tag Heuer Clothing Accessories
Clothing Accessories Logo
26 people viewed this question
Top Tom Ford Clothing Accessories Experts
Maxumized
Erin Wood
Erin Wood
Paul Parrish
Paul Parrish
Level 1 Expert
Are you a Tom Ford Clothing Accessory Expert? Answer questions, earn points and help others
