Question about Proform XT 70 Treadmill
Plastic rubs belt - Proform XT 70 Treadmill
I have a 2002 Ford Escort i replaced the alternator fine, then had to replace the serpentine belt yesterday i got the new belt and took the old one off. When i put the new belt on it started up fine no...
No the belt should should not rub on anything. Go to a ford dealership and ask the parts counter guy for a diagram of the belt routing they should print you off a copy no problem. all the ones i go to are happy to assist
Oct 01, 2011 | Cars & Trucks
The serpentine belt is falling off durning wet weather
Hi Brenda !
I am sorry to hear about your problem with your 99 voyagers serpentine belt falling off in wet weather !
I am suggesting that the harmonic ballancer is at fault.
The harmonic ballancer is the pully that is on the engines output shaft on the front of the engine (the transmission is on the back side of the engine).
I am assuming that the rubber bushing that holds the outer ring with the serpentine belt pully on it has detatched and is causing a misallignment of the pully to the belt , causing the belt to glide off.
I am unsure how this relates to wet weather though...
Inspect the pully by turning the vehicle OFF and looking in the wheel well behind the tire. There is a plastic shield there to keep the water durring wet weather from spraying on the belt and accesories... look and see if the plastic has been damaged (possibly a round 'rub thru' where the harmonic ballancer pully rubbed it ?).
Sep 30, 2011 | 1999 Plymouth Voyager
Can the plastic sheet under the walking belt be purchased . My belt is making a "squealing" noise as it is rubbing off the plastic sheet,which has become "pitted" and worn,This plastic...
dear
we named this sheet deck and it is not plastic but it is wood coated MDF you can measure it and buy any wood shop.
we would be glad help you by smartphon contact us 00989195116738
Sep 10, 2011 | Proform 790T Treadmill
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
Vibration on left side just had timming belt replaced
hi dont want to worry you, but i would get the engine mounts checked out they might not have tightend them enough after doing your belt, is it a bad vibration? does it only happen when starting and brakeing? is it a vibration or a plastic rubbing noise? as this could be the wheel arch protector not screwed up correctly, or even the timing belt cover rubbing on the belt...just a couple of things you can check out...hope this helps
Feb 18, 2010 | 2004 Hyundai Santa Fe
Engine is making a weird rubbing noise, could it be the belt?
the belt may be rubbing against the plastic guard...look around the guard area for very small particles of rubber...if none found, then it wont be the problem
Jul 27, 2009 | 2001 Nissan Maxima
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Eureka 5843 belt keeps slipping off of drive spindle.
Tough one. Typically the only 2 things that the belt contacts is the motor drive spindle and the brush roller. Anything else would only be there to protect the belt from debris. Can you turn the brush by hand and see why the belt is coming off? Is the spindle wobbly? If so, you may need another motor as I don't think it is easy to get parts for the motor. Hope this helps and good luck!
Mar 22, 2009 | Eureka Whirlwind LiteSpeed 5843 Upright...
Proform XT 70 Treadmill Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
