Question about Toys
Gator GS8 sports cam will not charge up
Brand new never been used. Indicator light turns blue instead of red when plugged in to PC indicating that camera is in user mode and not charging.
SOURCE: Jabra BT 5010
I have the same exact problem... I went to the shop and replaced it and again the new one doesn't charge. F***** jabra did anyone tried to call the jabra support about this ?
Posted on Jul 24, 2008
SOURCE: Not charging
Try to turn on the Keyboard.
There's a switch in the right side of the Keyboard.
For more information download the User Manual at Logitech Site
Posted on Nov 06, 2008
  • 7 Answers
SOURCE: Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
  • 5603 Answers
SOURCE: why my 28v doesn't fully charge
One or more cells of the battery have gone bad. The technique of measuring the state of charge of the battery is VERY limited.
I would recommend letting the battery cool after charging... THEN in a day, charge it again without using it. Do this for several days and see if the battery improves. If not, time for new battery.
DO NOT discharge these batteries beyond the point where the tool starts to slow down. You will reverse charge the weakest cell from the ones still deliveing power and the reverse charge will permanently damage the weakest cell.
Posted on Nov 26, 2009
  • 20 Answers
SOURCE: My ASUS Eee PC Battery Indicator's going weird
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena11
Posted on Jan 03, 2010
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
Advent modena m200 will not turn on or charge.
Connect the AC power adapter to the laptop and confirm that the AC power indicator is on (I wish you stated the brand of laptop). If the AC power indicator is not on, try and get a working AC power adapter for your laptop and connect it to your laptop.
With the AC power adapter connected, you can power on your laptop. If the laptop powers on from the OS you can see if the Battery is charging or not.
If the laptop does not power with the AC power adapter connected, then the power port of the laptop is bad.
However, if all these are okay and the battery still does not charge, the battery is faulty and will need to be replaced.
May 15, 2012 | Advent Computers & Internet
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Gateway MX8734 crashed and will turn on for 1 second then die
try a new battery. It might be a bad brand of battery.
May 28, 2009 | Gateway MX8734 Notebook
My blackberry won't turn on.
I have a brand new blackberry put it on charge and there is no red light at all indicating its charging is that a faulty charger or phone?
Apr 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
