Question about Dell 1320c Laser Printer
Dell 1320c with printer app for Ipad does not print
MUKHTAR
  • 2017 Answers
SOURCE: My dell laser printer 1320c has printer error code
this error means
Replace DrumCart
091-935
Drum Full of
Waste Toner
The drum cartridge needs to be replaced. fro more information about how to remove it you can got to following link
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section22.html#172399
Posted on Sep 09, 2009
Testimonial: "Thanks very much for your help I will now order a new drum cartridge."
  • 112 Answers
SOURCE: dell 1320c printer
Here is a link where you can download the manual.
http://www.retrevo.com/support/Dell-1230c-Printers-manual/id/23135bh943/t/2/
Please let us know if this helps. Thank you.
Posted on Sep 16, 2009
  • 4 Answers
SOURCE: Dell 1320c prints black as light grey. Tonor
This isn\'t a fault with the printer, IT IS A FAULT WITH THE WAY IT HAS BEEN SET UP! The problem is, not all of the tabs have been removed from the PHD unit inside. In order to remove these, you need to open the front cover of
the printer, move the four tabs 90 degrees and pull the whole PHD out.
You will then see the four yellow tags on the side.
Having printed with the tags in means the PHD has been potentially
damaged. If you\'re lucky, you\'ll get away with removing the tags now and
it will return to normal after about 50 pages, it not then you\'ll need a
new PHD. The reason the problem manifests itself with black first is
because the black is the most commonly used colour.
For info on removing all the tags, see here:
http://support.euro.dell.com/support/edocs/systems/prn1320c/en/ug/1320c_en/section04.htm#1055182
Posted on Oct 03, 2010
SOURCE: Dell 1320C
On page 30 of the 1320c manual it says this signifies the coming end of the PHD (print head device). I cannot find a part number or reference to the PHD on the Dell web site pages connected with this printer
Posted on Dec 15, 2010
SOURCE: 1320c Dell Printer has blinking orange error
If the light is flashing, it might not be the PHD, but you might be having a problem with the PDL emulation. Just go the control panel, right click the Dell printer. Select printer properties, not properties. Go to the advanced tab and check print directly to printer instead of spool print documents. This should work.
Posted on Feb 05, 2011
Cannot print to Dell 1320c printer
check printers on computer select your printer as default
May 02, 2016 | Dell 1320c Laser Printer
Does not print with printer app for Ipad
check and see if it is on the airprint official printers list on the apple site, if not, download the printcentral app from app store
Nov 25, 2013 | Dell 1320c Laser Printer
Dell 1320c printer is squeaking when printing
Hi, my Dell 1320C has started making a squeeking noise when it prints. It's like some rolling parts need oiling. Any suggestions?
Feb 28, 2012 | Dell 1320c Laser Printer
My Dell 1320c is print reds as yellow! What can I do?
Hello
Check your toners, maybe some colors (like cyan) is empty. You can use this guide on how to change them:
Dell 1320c Maintenance
Sep 07, 2011 | Dell 1320c Laser Printer
Dell 1320c print spool issues
Today I installed my new printer Dell Color Laser Printer 1320c. I cannot print as documents sent to spooler. I tried reinstalling. o good. I disabled spooler...no good. I'm a technophobic with little spare time, running own business and cannot print the documentation I need. Any help out there?
Jul 02, 2011 | Dell 1320c Laser Printer
EXCLAMATION MARK ICON UNDER RED X BUTTON FLASHING AND WILL NOT PRINT.
you will have to reinstall your dell 1320c laser printer and/or its drivers
Dec 22, 2010 | Dell 1320c Laser Printer
Dell colour laser 1320c printer prints one page
in your printer properties set the paper size according to your printer paper size.
Nov 27, 2009 | Dell 1320c Laser Printer
The black prints light grey. It has new toner
Printing - Light - After - replacing - toner
Bleed the cartridge- yes bleed it, if the black is grey, print lots of BLACK, in 'greyscale' like pages of it, probably 20, I had a customer with the same problem, I am and experienced tech and I own a shop, Dell couldnt help, Dell didnt know, I figured it out by looking at the way the printer works. Enough said.
* I am a HP person* ( as far printing goes )
Personaly HP is the best, anybody, and I mean ANYBODY who builds a printer that is NETWORK capable, Puts network interface in it that is a 'dummy' interface that you can actually plug a network cable into and it lights up.... then you figure out the interface you are trying to use is dead!!, How bout a laser printer that doesnt support PCL.... they say it does..... it may 'emulate' PCL.... probably does.... but the drivers will not print DOS apps correctly.... DOS may be dead,,, but there are SOME companys still using DOS based programs..... Dataflex is one..... I am not trying to write a review, my opinion, Dell 1320c is junk.... junk..... it is the cheapest of cheapest, in design, print quality, anything..... I have 4 Dell 1320c's that i am dealing with at the moment, at 3 different companies .... I am pulling out my hair with failed print jobs, (usb) of course, are they worth buying the network interface to make them network printers???? (get away from usb connectivity issues)--- no they are not, my accounts with HP's.... no problems!!! ---- none --- actually so good, we 're-geared' a HP, total cost---- more than it was new,, more than the Dell 1320c...... BUT KEEPING THE HP is what I and the customer knew to do.... when you wear the gears out in a printer and the only thing you put into it was toner's and two drums... during it lifespan... You bet your britches thats the printer to keep.... ('twas hp4100 n)..... HP 3600n is my choice for a Dell 1320c replacement,, Ummm yea... the 3600n uses toner cartridges that are NOT remote tanks..... they are integral.
Dan Antos
www.djantoscomputershop.com
Apr 30, 2009 | Dell 1320c Laser Printer
Dell 1320C
Jan 30, 2009 | Dell 1320c Laser Printer
Dell 1320c Laser Printer Logo
56 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
