Question about Koolertron For Toyota Highlander / Kluger / 7" Hd Screen Gps Navigation System With Dvd Player With Ipod Pip Rds Virtual-cdc
Drain fuel tank on a toyota kluger
I need to drain the tank as it has been filled accidentally with diesel. is there a plug or a drain point ?
Where's the fuel tank plug for a Kia Optima and I can't even get the vehicle to start. DIESEL was accidentally put in the tank
no drain plug and wont start or if starts will barely run or stall need to drop tank to get all diesel out also will need to flush lines
Aug 17, 2017 | Kia Cars & Trucks
How do i drain my 98 mercury mountaineer gas tank? I accidentally put diesel fuel in n now it wont start!
You're gonna have to drop the fuel tank to dump it. Also, you're gonna want to change the fuel filter and flush out your fuel lines when done. You may still have to replace some of the upstream parts (fuel pressure regulator, 1 or more injectors, various seals).
Jan 26, 2017 | Mercury Cars & Trucks
3:1 gas/ diesel in 2011 kia what can I do to remove it?
This site may have all your answers:
http://www.autobytel.com/car-ownership/maintenance-repair/accidentally-putting-diesel-in-a-gas-car-104029/
Basically do NOT drive the car and have the gas tank drained or talk to a mechanic.
Accidentally putting diesel in a gas car If you know that you have accidentally put the wrong fuel in the car, then don't compound the mistake by driving the vehicle while trying to think about what to do. Instead, call your mechanic immediately. At this point, the damage isn't permanent. If you drive and continue to drive, at one point the vehicle will stop and you will still have to have it towed.
There are two things you can do to try to fix the damage:
1. Try to clean up the damage yourself - have the vehicle towed home if it's not there already, and get as much of the diesel fuel out. How? By siphon if you can or any other method that you have available. Once you have as much of the diesel out as you can, fill the tank with the correct unleaded fuel that you normally use. Try to start the vehicle. It could take several attempts but it will start and it will smoke - a lot. It will continue to smoke until the last dregs of the diesel make its way through the system. It might run a little rough until everything is cleaned out. How it runs will depend on the proportion of diesel fuel relative to gas left in the tank.
2. Alternatively, have your vehicle towed to where your mechanic is and have the fuel tank drained of all the diesel fuel by a profession. They are also likely to flush out the whole fuel system. If the diesel stays in there for too long (and who knows how long is too long for your particular vehicle), it could ruin the fuel pump, lines and injectors. It is also possible that the diesel could have gummed up the spark plugs and filters. If this is the case, they will probably need to be replaced. Getting a professional to do the job will cost you anywhere from $100 to $500 and possibly a little higher depending on the extent of the damage.
Dec 29, 2015 | 2011 Kia Sportage
Mitsubishi forum
Most tanks have no drain plug due to safety regulations the only way is to remove the tank and drain it from the top
Aug 15, 2014 | 2014 Mitsubishi Outlander Sport
Hi I,ve just filled my diesel tank up with petrol
disconnect fuel line bypass fuel pump relay and drain
Sep 25, 2013 | Toyota Land Cruiser Cars & Trucks
Gasoline in a diesel tank
Hi,Did you start the vehicle after you put the gas in the tank? A drain plug is fitted underneath the tank,drain the tank of gas then fill it half way or more it may run a little sluggish at firs but the amount of diesel to gas ratio will mean it will do no harm.Hope this helps.
Sep 22, 2012 | 2006 Opel Meriva 1.7
I mistakingly put some diesel in my petrol swift
You don't say how much diesel you put in or how much petrol was in tank in the first place. If the amount of diesel is less than 5 % of the total then you may try filling tank with petrol and keep topping up to dilute the diesel. The best fix would be to drain fuel tank completly and refill with petrol. If tank has a drainplug , this will be easy but if no drain plug you will have to remove tank from vehicle to empty it.
Nov 07, 2010 | Suzuki Swift Cars & Trucks
Drain plug?
um you will have to take the whole Fuel tank off to drain the toyota. sorry to tell you. They are no longer able to put drain plugs in the fuel tanks do to Crash Saftey.
if you need help on removing the Fuel tank let me know in a Comment and i will be more than happy to give you the information you will need.
Please rate me if you would
Thanks
Aaron
May 05, 2009 | 1992 Toyota MR2
Need to find drain plug for fuel tank for 1992 mr2, filled with diesel
Yikes...should have a plug at or near the center of tank underneath. 3/8 ths. need a effective catchment system to drain the fuel into. Lift the vehiche. Gonna get messy.
I accidentally put regular gas in my 2001 dodge deisal truck.
Hi yes just drain the tank completely and replace the fuel filter, fill with DIESEL ;-), then just strart her up ,, it may take a bit to get going but should go in the end and run fine,
Hope this helps
Steve
Mar 21, 2009 | 2001 Dodge Ram 2500 Truck
Koolertron For Toyota Highlander / Kluger / 7" Hd Screen Gps Navigation System With Dvd Player With Ipod Pip Rds Virtual-cdc Logo
98 people viewed this question
Top Koolertron Computers & Internet Experts
David Payne
David Payne
Are you a Koolertron Computer and Internet Expert? Answer questions, earn points and help others
