Not access to local sharing folder and attached printers acer 4715z
I have an acer 4715z which is not able to connect with local area group computer though i can brose internet while shared folder are unaccessable wht i do
  • 822 Answers
Your using xp if im rigth. go to my computer+manage+local user+click guest properties...then check dialog box disabled password. be sure you share your file.
Posted on May 08, 2009
How to use comupter as sever
Proxy server
Use a Computer as a Proxy Server
Small networks can still take advantage of a proxy server.
The Microsoft Windows operating system allows you to turn your computer into a proxy server.
A proxy server is a central computer on the network connected to the Internet.
Other computers on the network use the machine to connect to the Internet.
The Internet Connection Sharing (ICS) configurations on the machine allow you to turn your computer into a proxy server.
Click the Windows "Start" button and select "Control Panel."
Double-click "Network and Internet Connections."
Double-click "Network Connections" to view a list of network card settings.
Right-click your network card icon and select "Properties."
For most users, this icon is labeled "Local Network."
Click the "Advanced" tab.
Check the box named "Allow other network users to connect through this computer's Internet connection" in the section labeled "Internet Connection Sharing."
A warning message pops up telling you that your IP is reset for the proxy computer.
Click "OK."
Reboot your computer for the settings to take effect.
You also need to reboot each client machine on the network to ensure they see the proxy server.
Turn a Computer Into a Server
When you have more than several computers and users who want to share files and resources, whether in your home or in a small office, you can convert a computer into a server.
Building a server out of a computer will allow users to access files whichever computer they use to access them.
An example of the resources that can be shared is a printer and shared folders such as photos and documents. Here's how to convert a computer into a server.
Prepare your computer.
Clean up the computer with unnecessary files to save on space.
If your computer is really old, install the latest operating software so that it is compatible with the rest of the computers that will share its resources.
For this example, we are installing Windows XP.
Check the hard drive space or capacity if you have enough.
You can do away with 256MB sized old computer, but you may want to think about adding more disk space for future needs.
You can easily buy extra internal or external hard drives to bump up your disk space to a capacity that you would desire.
Try purchasing a 10GB extra disk drive then insert it in computer or connect via a serial port or USB hub it if it is external drive.
To install the hard drive driver on XP, let the hardware wizard run you through the options.
You can install the driver with the installation CD software that your hard drive came with.
Follow the options during installation. ,
Check your computer if the network card (ethernet card) is functioning properly. if it does not, you would need to install a NIC or Network Interface Card.
Some old computers have 10 megabit cards, but if you want to have high network performance and better connectivity through your LAN (Local Area Network) then you would need to upgrade your NIC by installing a 100 megabit or 10 gigabit NIC.
Install your network card driver using the installation CD that came with it then follow the installation wizard.
Get a network router. Connect this router to your high speed connection.
The most common ones to use are Netgear, Linksys or DLink routers.
Choose a wireless router so that if you have wireless users they can connect easily (plus this will save you on trying to connect cables to the router all over the place).
Set up your network connections.
Click on "Start," "Control Panel and "Network and Internet Connections."
Pick a task from the options listed or pick a control panel icon, in this case "Network Connections."
If you are set up to pick up the IP Address of your computer automatically, one you have installed your NIC in Step 4 and rebooted, it will pick up the connections automatically whether plugs in using a LAN or network cable or using wireless card.
Rename your computer. Name it so that it can easily be identifiable in your network.
You can either name it simply "SERVER" to be easily recognized, but it is all up to you how you want to name your server.
To name your server if you are using Windows XP, you can right-click on "My Computer" then click on "Properties."
Go to "Computer Name" tab then click on "Change."
Other Windows operating systems or versions would have this feature located somewhere else. Read the owner's manual that your computer came with it.
Create a shared folder by going to "My Computer" and "C:\Documents and Settings\All Users\Documents."
Create a new folder by right-clicking on the screen, then click on "New Folder."
Name the new folder "Shared Files" or anything that can easily be identifiable.
Take note that on Windows XP, any folder that you create and then dragged into the "Shared Documents" folder will be automatically shared by everyone.
You can restrict certain folders by dragging the folder out of the "Shared Documents" folder, then right-clicking on the file folder, clicking on "Properties," then the "Sharing" tab and finally "Make this Folder Private."
Create a shared resource by adding a printer or fax to use. Go to "Start."
Click on "Printers and Faxes" and "Add a Printer," then let the installation wizard that came with the printer or fax guide you.
Name your printer or fax (for example, "Shared Printer").
Then once the printer is installed, set it up so that you can share it by right-clicking on the "Shared Printer," then on "Properties," "Sharing" tab and finally on "Share this printer."
Connect any computer to your server.
Go to each computer and ensure they are connected on the same router.
Then go to "Start" and "Run," type in "EXPLORER," then on the menu click on "Tools" and "Map Network Drive."
A window will pop open where you will assign a "Drive" letter and a "Folder."
Choose any driver letter, for example "G" to denote "Group" drive or "S" to denote "Shared Drive," then type in the IP address of the server.
To do this, go to the server, then go to "Start" and "Run," type in "CMD" then type in "IPCONFIG." This will display your server's IP address.
Type the IP address on the "Folder" field on the computer.
You can also try if the computer will automatically find it by choosing the drive letter then clicking on the "Browse" button on the "Folder" field.
Start using the shared resources by going to the drive letter that has been assigned on your computer.
Sep 24, 2013 | Computers & Internet
Hi, I have two pc running with windows xp operating system. From User 1 i need to access user 2 windows folder and program files folder otherway around also but I can't how? Even if I shared windows folder...
First thing Windows XP Home Edition will give you numerous problems when sharing files, you should consider using windows XP Pro for that sort of operations.
Assuming you have Windows XP Pro installed in both computers:
1 - Create the same user on both computers ( same account name, same password ) blank passwords are not allow between file sharing as per windows xp group policy.
2 - Create a resource to share ( example: C:\)
3 - Disable simple file sharing
* go to control panel
* click on folder options
* click the VIEW tab
* unckeck the use sharing wizard
4 - Make sure that the user that will be used for authenticating between computers have the proper NTFS permissions and the proper access to the shared sources.
5 - Try to connect to the shared sources when asked for username and password type the credentials of the newly created user.
Now you should be able to connect to the shared sources both ways.
Oct 18, 2010 | Computers & Internet
How can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
How to I install a shared printer successful, to a acer laptop as well as a Dell desktop.
to install shared printer first you have install printer in a desktop or laptop. after that share the printer. for that go to printers and faxes ? right click share the printer. give a name to identify the printer. Go to other system open network places ?entire network open system which you installed printer > open printers folders and right click on printer name select connect. If you cannot access system from network places. type ip address of system (in which printer is installed) on where you want to install printer. ex: in run > type //192.168.0.25 and press enter and open printers folder and right click on printer and connect
Jul 13, 2010 | Acer Aspire One PC Notebook
How do i build a local area network in windows xp?
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
Dec 02, 2008 | Computers & Internet
I am trying to set a network using a wired desktop and a wireless laptop (desktop using XP and laptop using Vista)I am using a Linksys WRT160N, I can get on the internet with no issues at all but when...
in the router's lan (not wan) configuration - set the dhcp server (gateway address) to be 10.1.10.1. Then set the addresses of the clients (connected to the router) to be assigned addresses from 10.1.10.10 - 10.1.10.20. Set the desktop's TCP/IP address to be 10.1.10.11 (static) with a subnet of 255.255.255.0, and a gateway address of 10.1.10.1. Set the laptop's wireless connection (TCP/IP adapter) to have a static 10.1.10.12 address with same subnet mask and gateway address of desktop. Change the workgroup on both computers to be of the same name (case sensitive here) to a name such as HOMENETWORK. Then on each computer, open up "My Computer" and right click on folders, files or printers that you want to share on your network!
Sep 26, 2008 | Computers & Internet
Ricoh 2045
Yes.
Go to your desktop. Create a folder named "scans" on the desktop, and share it. Give the "everyone" group full access, or give users permission to modify files. Depending in how its set up.
On the copier, since you already have Email setup, your dns servers will be entered. Go to:
user tools, system settings, admin tools, address book management. Either select a user, or new program. Fill in user name ect. Select folder. It will ask for a path. Enter the path using the following template"
\\computername\scans. You should be able to test it out. If it is successful, then it will prompt you to login. This is your local login for the computer with the scans folder, The password is its password. Press ok to save.
Select scanner, scan document to the user that you set up. If the memory goes from 100%, to 99%, to 100% quickly, it worked.
You can use variations of this on a server too. If its a domain server, assigned to a group, the user name and password are what the user uses to access the active directory.
Mar 28, 2008 | Ricoh Aficio 450 Copier
Wireless prob
Open the Printers and Faxes folder on the computer that was connected to your printer.
To open the Printers and Faxes folder
• Click Start and then click Control Panel.
• Click Printers and Other Hardware, and then click Printers and Faxes.
• In the Printers and Faxes folder, Click the printer's icon and, in the tasks pane, Click Share This Printer.
• Open the printer's Properties dialog box, and clicked on the Sharing tab.
• Click Share Name, and then click OK.
That's it—the printer is immediately available for other computers to use.
Now that you have a network printer, Your was ready to connect to it and print from other computers on the network.
To connect to the printer:
• Open Control Panel, and clicked Printers and Other Hardware.
• Click Add a Printer.
• Instead of adding a local printer, click Printer Connection and then browse the network for the printer.
Jan 12, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
