Question about Konica Minolta Office Equipment & Supplies
Whats a polygon motor in konica minolta C353 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,680 Answers
The polygon motor is the motor that moves the LASER beam to each of the drums or drum depending on the set up it moves around 34,000 rpm give or take and is enclosed in the print head for the yellow,cyan,magenta and or black PRINTHEAD. You dont replace it you replace the Printhead
Posted on Mar 25, 2018
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
Bubbabear64
  • 2794 Answers
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
Posted on Jul 06, 2008
firecontrol7
  • 6680 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Posted on Jul 31, 2009
herminio_hal
  • 210 Answers
SOURCE: I need to scan to email using the c353 konica
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Posted on Aug 11, 2009
  • 5 Answers
SOURCE: Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
Posted on Sep 02, 2009
How do you fix code error 5102 on konca minolta bizhu c353
check the paper draws and registration assembly. or might have a burned out transport motor worse case main board
Jan 23, 2017 | Konica Minolta Minolta Bizhub C353 Copier
Magicolor 8650 polygon motor
Polygon motor is located inside the print head along with the LASER
Apr 30, 2014 | Konica Minolta Konica-Minolta 4599161...
KONICA MINOLTA C353 ERROR CODE C-5102
hi tracey, 5102 is a main motor failure, it is possible for there to be paper jammed tight in the fuser unit, if not this will pretty much be guaranteed to be the main motor
Nov 11, 2013 | Konica Minolta Bizhub C353 Copier
I have a trouble code C-3727 showing on my photocopier konica minolta bizhub C353. What does that mean?
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.Or in case You Still Having Konica Printer Problem Then Follow Us For On: Konica Printer Support
Oct 06, 2013 | Konica Minolta Konica Bizhub C353 Drum...
"konica minolta bizhub c353 error code c-4154"
"konica minolta bizhub c353 error code c-4154" help
change the chip and the imaging unit and still the same
what else I can do ??
help me please?
Thank you ...
Mar 09, 2013 | Konica Minolta Office Equipment & Supplies
KONICA MINOLTA PagePro 5650 error code of 0300 Polygon MOT
Polygon motor is inside the print head where the machine LASER is located the motor spins around 35,000 RPM. Moving the LASER beam across the drum with image. Sound like you need a new print head. Try the below web sit for a start.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 09, 2012 | Konica Minolta PagePro 4650EN - Printer -...
I have konica minolta bizhub c353 i have problem
Most likely it is your magenta cartridge or magenta developer unit.
did you recently change cartridge?
Are you using original cartridge?
Nov 13, 2010 | Konica Minolta bizhub Office Equipment &...
Error code c4101
Error cod C4101
Machine Konica Minolta c6500
Nov 25, 2009 | Minolta bizhub 200 All-In-One Printer
139 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
