Question about Acer Aspire 5112WLMi Notebook
Cant locate the BIOS battery - Acer Aspire 5112WLMi Notebook
    President:
  • 987 Answers
You have to open the back cover of the laptop...then you can find a battery located on the motherboard...
Posted on May 08, 2009
CANT ACCESS BIOS
Remove CMOS battery (Large button battery on the main board). Removing the CMOS battery like the one shown in the picture causes the system to lose all CMOS settings; including the password. To do this, locate and remove the CMOS battery from the motherboard for at least five minutes, then replace the battery and turn the computer back on
Jul 06, 2016 | Computers & Internet
Why wont my equium a100-337 wont post to bios, says there is a problem with the TPM? wont load bios menu either and hangs?
TPM is the security system in the bios.
If you can open the laptop remove the bios battery - most laptops dont have a bios reset jumper.
May 01, 2014 | Amstron Toshiba Equium A100-337 Laptop...
What is the factory setting of the bios password (after F10) on my presario R3000
if you cant remember the bios password simply make sure its plugged out remove the laptop battery locate the cmos battery and remove this for about a minute or two, then replace everything, this will make the bios reset and hopfully the password will be removed
hope this helps
Feb 20, 2011 | Compaq Presario R3000 Notebook
I am using acer aspire 5052ANWXMi and somebody has changed my bios utility password and now I cant enter set up..Asmy operating system is nt working I cant boot from Cd to install it as it needs bios...
If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battery, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battery & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Dec 18, 2010 | Acer Computers & Internet
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
Toshiba a215-s4697 locate bios battery, becuase i can not remember my bios password so i cant do anything with my laptop
I am not sure that the removal of the CMOS battery would erase the passord on boot. Better take it to a Toshiba Certified Service Center.
Hope it helps.
Sep 30, 2009 | Toshiba Satellite A215-S4697 Notebook PC
Bios password
now, my computer start windows and don't have type arrow so please help me and what me do? thank you.
Aug 20, 2008 | Acer Aspire 4315 Notebook
Cant login to bios
Try doing a bios reset using the BIOS RESET button on the motherboard, usually located near the battery.
Jan 12, 2008 | ASUS P5RD1-VM Motherboard
Acer t180 bios set up
hmm you might need to flash the bios or reset the bios follow these instructions.
TO RESET BIOS
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
THATS IT BIOS RESET
Jan 10, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire 5112WLMi Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
