Question about Powercom VGD-1000 (VGD-1000) UPS System
Ac fuse blown in Powercom VGD - 1000 UPS - Powercom VGD-1000 (VGD-1000) UPS System
3 Suggested Answers
SOURCE: I have a powercom (VGD 1000 VA)online UPS.All
It sounds to me like you have a shorted cell in one of the batteries and the current limiting resistor on the charging side is out of tolerance (too low). Though it is more likely that they fail too high, they can go low in the event of overheating. I would check the resister with an ohm meter vs what is printed on it. It should usually be within 10 to 20% you can put one in series to limit the current, but you need a high current diode in parallel with it as no to limit the current to the inverter. I don't remember, but i think your model uses 2 12vdc batteries. You should replace all of its batteries and check the resister. Also, if there was a plastic insulator on the old mosfets you took off, you must have it on the new ones. this is to isolate the collector from ground. I home this helps,
Ryan
Posted on Apr 19, 2009
SOURCE: ups after 1 hr automatic disconnected and on only battery mode.
MY IND601A powercom UPS GETS OFF DIRECTLY
WHEN THE POWER GOES OFF?
Posted on Dec 26, 2009
My ups is switching on on battery for few seconds but without AC output, the same thing when I put AC power it switches on normally but also without AC output.What can I Do? Please help
does it have a led display for battery charge? if it is very low battery is bad,when you add a/c no output because bad battery will not provide a/c in power failure
Feb 02, 2011 | Powercom (BNT-1500AP) UPS System
My powercom ups canot power on
hi there check the fuse and let me know the condition of that.
Jan 19, 2011 | Powercom BNT-600AP (bnt600ap) UPS System
IN POWERCOM UPS 1500VA I NEED THE VALUE OF THE RESISTANCE R74 , R67, R51,AND R49 THANK YOU
first u have Chaque the color coding of resistance and u fine exact value of resistor.
Mar 15, 2010 | Powercom (BNT-1500AP) UPS System
My ups shuts down after ac power goes off
1. Open the UPS housing using a screwdriver.
2. Check the fuse. If is busted, have it replaced.
3. If the fuse is alright, check the battery terminal
for the stored voltage. It must be at least + or -
10% of the rated voltage of the battery. The rated
voltage is located at the battery. (12 volts). If the
voltage is below, 8 volts or only 30% of the rated
voltage. It must be replaced.
4. If the battery
Sep 25, 2009 | Powercom (BNT-1500AP) UPS System
Ups after 1 hr automatic disconnected and on only battery mode.
I have to believe that the problem is in the smart chip, with the software that monitors the power. There is a very good chance that you have a slightly higher input voltage then normal. You may have to contact Powercom.....
I don't think you are in the USA...I sell Powercom and I don't recognize the part number. I think this is simular to the IMD 625 Va UPS sold here in the USA. The imperial model had a defect on the smart chip two years ago here in the USA, and I figured it out for the MFG, so maybe that same chip is acting up for you. Besides, the 600VA size should be too small for you know. You should upgrade to a 1000VA. It will handle the load much better.
Aug 26, 2009 | Powercom Computers & Internet
My Powercom UPS overload
remove all loads, unplug it, turn it off, wait 1 minute, plug it in, turn it on, apply loads. if this does not solve the problem, replace it.
Jun 08, 2009 | Computers & Internet
I have a powercom (VGD 1000 VA)online UPS.All MOSFET (IRF 3710)had been shorted and DC fuse cutted off.I mounted all 6 mosfets and DC fuse.Display has been come and it gives out puts in AC mains but not in...
Ryan
Apr 06, 2009 | Powercom (BNT1000AP) UPS System
Powercom VGD-1000 (VGD-1000) UPS System Logo
Top Powercom Computers & Internet Experts
David Payne
David Payne
Are you a Powercom Computer and Internet Expert? Answer questions, earn points and help others
