Question about Kitchen Appliances - Others
En12486 needs new stopper top - Kitchen Appliances - Others
I have a Model 2464S that I need a new stopper for. The stopper model number is 764.
Is this stopper for your vacuum sweeper or some other appliance? You submitted your question in Vacuum Sweepers section of fixya. You also didn't say what brand of appliance you need a stopper for?
Dec 28, 2013 | Vacuums
The strainer/stopper is stuck in the kitchen sink the sink has a disposal unit attached. How do I remove it from the top
We just experienced the problem describe in this question. A dinner guest pushed the strainer stopper past the Blanco flange over the disposer and the stopper could not be removed by pulling straight up. The Blanco flange is difficult to remove so we knew that removing the flange would be a last ditch effort. I tried using several tools trying to deform the stopper enough to lift past the lower part of the flange but without success. While I was on the internet looking for a solution, my wife found the obvious answer. She pushed the stopper down into the disposer, rotated it 90 degrees. She then aligned the edges of the stopper with two of the small indents in the lower part of the flange. The stopper was then pulled up past the flange where only two points on the circumference of the stopper contacted the flange.
Kudos to her for this simple solution.
Sep 24, 2012 | Blanco Sink Waste Strainer / Stopper...
How does the lift and turn stopper come out so we can clean plugged drain?
  • Push the stopper down to fully seal the stopper against the tub drain.
  • 2
    Turn the knob on top of the stopper counterclockwise with your fingers. Do not lift the stopper while turning the knob. Remove the knob from the stopper.
  • 3
    Insert a large flathead screwdriver into the slot on the center shaft of the stopper. You will see the center shaft when you remove the knob. Turn the shaft counterclockwise to unthread it from the retaining hole in the bathtub drain basket.
  • 4
    Use a pair of vise-grip pliers to turn the shaft if the center hole has corrosion and will not accept a screwdriver. Lock the jaws of the pliers securely around the shaft, and turn the shaft counterclockwise.
  • 5
    Pull the stopper out of the tub by lifting it by the shaft.
  • Mar 12, 2011 | Maax Soprano II: One-Piece Shower Module...
    We have a delta tub stopper that lifts straight up and does not turn. We need to remove the stopper piece to take care of a blockage in the drain. How do we get the stopper out?
    Hold the stopper and unscrew the top piece and u will find a screw and if not this style it should turn with a little extra fource...Hope this helps.
    Aug 11, 2010 | Home
    I stopper on a garden tub with a delta faucet. The stopper pushes down and locks to stop water. It takes a few tries pushing it down to get it to stop and hold water. What is the best way to fix it or...
    In my part of the country, the type of drain you refer to is commonly called a tip-toe drain because you can use your toes to open and close the drain. Their locking ability diminishes over time and use, and eventually won't lock at all. They cannot be repaired, and must be replaced. You must remove the one you have to get the correct replacement because there are variations in the thread diameter at the bottom of the stopper.
    You will need to use pliers large enough to grab around the white plastic underneath the top of the stopper that appears to disappear into the drain. Once you have the white plastic shaft secured with pliers, grab the very top (the chrome part) and twist it counterclockwise to remove it. Once that is off you will see a round piece of brass that looks like the top of a very large screw. IT IS! Using a stantard screw driver, again turn counterclockwise to finish removing the rest of the stopper.
    A good hardware store should have a replacement for you. Be sure to match up the thread diameter at the bottom of the stopper.
    To reinstall, you can reverse the steps or simply thread the complete assembly into place.
    Aug 07, 2010 | Home
    How to replace kohler bathtub stopper?
    If it is not a cable operated drain stopper, most have a knurled push pull knob on the top of the stopper. This knob should twist off to the left exposing a screw slot in the middle of the stopper. Using a flat blade screwdriver turning left until the stopper is free. If it is a cable opperated stopper, it is best to get a pro to replace it. If the cable is damaged and needs to be replaced, the tub will have to be pulled to do this job.
    Sep 12, 2009 | Home
    Gas tube came out of gas tank
    If the rubber stopper is still plugged into the tank pry it out go to a small engine shop and buy new gas line.Thread the new line into rubber stopper to poper length,plug filter (new)on end that is going in tank then pop he rubber stopper back into the tank body.Have done hundreds and it isn't hard,you may need sone WD 40 on stopper to thread line and popping stopper back in .Good Luck
    Jul 19, 2009 | Homelite Mighty Lite Lawn Trimmer
    Deco Lav 9298 Closing Umbrella drain will not close
    sounds like you need a new stopper i had the same trouble bought a new stopper they don't cost that much
    Feb 27, 2009 | Deco Lav DECOLAV Decobronze Push Button...
    STOPPER
    any shop that sells quinnys should be able to order from quinny for you! i lost my brake pad and my supplier ordered it for me and it only cost me £5
    Nov 15, 2008 | Quinny ZAPP Stroller
    Kitchen Appliances - Others Logo
    32 people viewed this question
    Top Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
