Question about GE GDS20KBS Bottom Freezer Refrigerator
Fridge too cold
Originally my fridge would not take in cold air, the freezer worked fine but the fridge was not cooling. I called a repairman to look at the fridge and he found that the fan was burnt out. He replaced the fan and this started the fridge getting cooler again, but after 24 hours fridge started freezing from the bottom up.
I've put both the freezer and fridger temperature setting to 1 and 1, but this doesn't seem to stop the cold air in the fridge.
When I open my fridge I can feel the cold air coming up from the freezer - is some sort of control that isn't working that controls the amount of cold air the fridge takes in from the freezer? Could the thermostat be broken?
Is there a way for me to test to see what the problem is without calling in a reapirman again?
Thanks.
  • 6 more comments
  • Anonymous Jun 20, 2008
    fridge not working freezer under bottom drawer get full of ice
  • zie79 Sep 27, 2008
    i do have same problem about my fridge...all vegetable at bottom became frozen and egg was broken eventhough i've put lowest setting on my freezer. For your information i use LG Expresscool fridge.
  • andretripicc Nov 22, 2008
    my fridge is too cold...everything get frozen
  • dhinkel97 Apr 07, 2009
    I have an Amana frigerator that is set on the lowest setting and still manages to freeze food in the fridg part. This is an old school style refrigerator with the freezer up top. It is not a side by side, but a freezer up top and the frige part down below. Anyone know what to check out or do to warm it up bit? I'm pretty handy and don't mind trouble shooting. Thanks.
  • Anonymous Mar 18, 2014
    temperature control in the fridge won't work. freezer works fine
  • Anonymous Mar 20, 2014
    feeezer is 0* frige is 24*
  • Anonymous Mar 27, 2014
    as above
  • Anonymous Mar 29, 2014
    Just replaced damper control 22 days ago. Now again not cooling. Found crack in freezer side. Would that have anything to do with it?
  • 473 Answers
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Posted on Oct 10, 2007
Fridge is not cooling down. Freezer is fine only the fridge. Plus the water dispenser - water is not that cold
These units like most fridge/freezers, actually cool the freezer first, then a damper opens that flows freezer air into the fridge side cooling it. The thermostat/switch controls the freezer, the refrigerator is controlled with a damper. The cold water storage tank is usually hidden in the bottom rear of the fridge, behind the vegetable bins, so if the fridge is not cold the H20 is also warm. I suggest you unplug the fridge, empty the freezer and remove the covers. Your issue could be a simple ice blockage of the air passage, or a stuck or broken damper control. Use Sears parts to look up a exploded view of your fridge. At minimum, you will learn a bit, and if you end up calling a service guy, he will know he cannot fool you and overcharge you.
Jan 08, 2011 | Cuisinart Private Reserve CWC-600 Wine...
The freezer is working fine but the fridge is not cooling. The motor is running constantly. I did accidently leave the fridge door ajar for a few hours
Check to see if the cold air supply from the freezer to the fridge section is blocked and that the fan is running. The fridge uses cold air from the freezer to cool and many times the intake is blocked by something in the freezer compartment.
Sep 13, 2010 | Kenmore 72912 / 72914 / 72919 Bottom...
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer cold but fridge warm
first leave it off for 24 hours, and then put it back in operation. if its doing it again , then chck the heating element, defrost timer...
Apr 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge side is loosing cold.\the freezer side is working fine.
Check for proper operation of the damper door. This allows cool air from the freezer to cool the fridge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | Maytag Refrigerators
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
GE GDS20KBS Bottom Freezer Refrigerator Logo
1,995 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
