Question about Toyota Sewing Machines
The thread keeps coming off the take up lever on my Quilt 50 Toyota Quiltmaster while sewing.
Have tried adjusting bobbin tension, cleaning machine but still comes off while sewing.How do I stop it doing this?
  • Toyota Master
  • 7,365 Answers
Take a piece of tape and put the tape of the take up lever or take a pair of pliers and close the take up lever just enough so the thread will not come off. I had the same thing happen on one of my sewing machines.
Posted on Nov 26, 2013
  • 96 Answers
SOURCE: My bobbin thread keeps getting tangled and
there is a screw on the side of the bobbin case, which needs to be turned to the left or counter clockwise to loosen the tension and also change the needle because a burr on the end will cause problems with bobbin thread
Posted on Dec 13, 2009
  • 1116 Answers
SOURCE: How do i adjust the bobbin tension on a tesco ej09
Before adjusting the bobbin tension (small screw on the side of the bobbin case), try this.
Always thread a sewing machine with the presser foot up as this opens the tension control for the top thread so the thread can be properly seated for control when stitching.
Often what appears to be a problem with the bobbin thread is actually the top thread going loosey-goosey.
Posted on Apr 03, 2010
  • 1116 Answers
SOURCE: how do i adjust the bobbin thread tension?
Refer to page 15 of the manual - http://www.singerco.com/accessories/manuals.html
Before changing the tension settings, be sure to thead the machine with the presser foot up as this also has a tremendous effect on the tension and formation of the stitch.
Posted on Apr 29, 2010
male_28_cam
  • 1555 Answers
SOURCE: I have cleaned the bobbin
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
So if the threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
If tensions appear correct, and the thread is definately in the channel between the discs, try raising presser foot, remove thread and with a strip piece of fabric 8 - 10" (20 - 25cm) gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without being shown, it may end up with missing small screws and spring pieces.
Posted on Jun 24, 2010
SOURCE: our toyota Rs2000 quiltmaster 50 is not picking
1.is the needle bent or blunt
2.is there a 2 to 3 inch tail on the bobbin that it can be picked up
3.is there lint or thread fragments in the bobbin aea
Posted on Jul 31, 2010
How do I adjust tension on a Janome 1600p-qc for machine quilting?
Adjust the tension the same way as sewing regular projects. You want the top and bobbin threads to meet in the middle of the quilt sandwich. When quilting, I use a lighter weight thread so I have a separate bobbin case whose tension has been tightened specifically for quilting. For other sewing projects using a standard thread weight, I use a bobbin case that is factory set and then adjust the top thread tension for each project.
Aug 04, 2017 | Janome Sewing Machines
I have a Janome magnolia 7318. when I lower feed dogs to quilt it will not sew circles or feathers well. It pulls bobbin thread up on top in loops.
I've found that when FMQing, I usually need to increase the bobbin tension to keep the bobbin thread down (for this reason, I have a separate bobbin case that has the tension adjusted that is used only for FMQ). You may even need to decrease the top tension if the top thread is "pulling" the bobbin thread up.
Jun 18, 2017 | Janome Sewing Machines
Free motion quilting bobbin thread come to the top
check the timing between the needle and rotating hook also check the teeth for possible lost of timing maybe low or high to much.
Nov 06, 2013 | Brother CS6000i Computerized Sewing...
I just bought a singer stylist 9100 and its driven me to tears. The bobbin thread keeps couching through the top of my quilt, pulling the top stitches into a tight blanket stitch looking mess. I have...
Suggest you check your bobbin tension, pull the bobbin thread and if you feel it too loose, most likely bobbin thread not threaded correctly into the bobbin case tension plate. Do refer to your manual if you have one.
Jul 18, 2013 | Sewing Machines
Toyota quiltmaster
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the top.
Be sure that your top thread follows the correct thread path.
Set the top tension to the midway point.
Re-test your machine.
Tension is a tug-of-war between the top and bobbin threads. Correct tension is when both threads meet in the middle of the fabric. If the bobbin thread is laying on the underside of the fabric, the top tension needs to be increased so it will pull the bobbin thread up into the fabric. If the top thread is pulling the bobbin thread up to the top of the fabric, then the top tension needs to be loosened.
TIPS:
FWIW, thread tension is not static. Tension will need to be adjusted probably every time you start a new project. Test it on a piece of scrap fabric from the project and adjust it BEFORE beginning the project. Remember to change the needle often--probably every time a new project is started or every 8 hours of sewing time. Be sure to use the correct type and size needle based on the fabric & thread you are sewing. Also, AVOID old or bargain bin thread!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
All About Needles SCHMETZ Needles
Nov 24, 2017 | Sewing Machines
The bobbin thread keeps balling up when trying to use my 730 on quilt motion system
try changing the needle
try turning the bobbin the opposite direction in the case
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
if these suggestion don't help then the machine needs to be checked
Mar 06, 2013 | Bernina Sewing Machines
Stitch too tight on top, too loose on bottom
This is a problem with thread tension. The needle thread is too tight and the bobbin thread is too loose. I don't have one of these machines, but there should be either screws or knobs to adjust. Look at your manual. Here's a page I found on bobbin tension.
https://www.manualslib.com/manual/1022927/Toyota-Quilt-50.html?page=50
Aug 06, 2017 | Toyota Sewing Machines
Our toyota Rs2000 quiltmaster 50 is not picking the bobbin thread up how do we correct the timing
Jul 31, 2010 | Toyota SE-06 Mechanical Sewing Machine
My needle keeps breaking while I'm trying to machine quilt. It also at times will collect the thread on the other side of the quilt which makes me think something is wrong with the bobbin.
Q1.(A) Without realising, you could be 'helping' the material feed.
Q2. (A) Is the thread collecting at the start or during sewing?,,if at the start, make sure threads are clear and hold them out the back of work gently till a few stictches are made.
If during sewing, it could be tension isn't adjusted correctly, experiment.
Apr 27, 2008 | PfaFF Quilt & Craft Pro 7530
Sewing Machines Logo
50 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
