Question about Dynex DX-LCD37 TV
Dynex flat screen won't turn on red light lite when turned on and wouldn't go out when attempted to turn it off
Was working fine recently, today attempted to turn it on and red light only came on, no picture, attempted then to turn it off and red light remained on so it didn't turn off
    Top Expert:
  • Dynex Master
  • 74,136 Answers
The fault is with its main power regulator board itself. SMPS section is not oscillating. It will be best to contact any service technician. For more information go to http://electronicshelponline.blogspot.com/
Posted on Nov 26, 2013
  • 8 Answers
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Posted on Aug 21, 2008
  • 2318 Answers
SOURCE: Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
Posted on Sep 28, 2009
  • 8457 Answers
SOURCE: No Picture-white screen
Ur Tuner board,that the tv signal came into that board.U have a little manchanical skill.Take ur tv aparts.Replaced that Tuner board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board to replacement.
Posted on May 11, 2010
budmrtn
  • 11361 Answers
SOURCE: Dynex TV will not turn on, red light on as usual.
The standby 5vdc is working but not the rest.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 19, 2010
  • 5105 Answers
SOURCE: Dynex dx-l40-10a flat-screen hdtv turns on and the
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight. With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing
I hope this helps.
Posted on Jul 21, 2010
Testimonial: "thanks"
Gateway monitor 2100 won't turn screen on, blue lite is on as if monitor is. but screen is not on. can it be fuse or what ? is not v-card
It sounds like the lamp for your monitor is no longer receiving power. While you can attempt to fix this issue yourself I wouldn't recommend doing so as it doesn't mean it will work after you attempt it.
If the monitor is under warranty still then you should contact the manufacturer about a RMA. If the monitor isn't under warranty then you should purchase a new monitor.
Nov 26, 2011 | Gateway Computers & Internet
My Dynex flatscreen was cracked about a month ago,it worked fine after it warmed up until today... I tried to turn it on and now it has a black screen and won't turn off.
Working with a cracked screen has overstressed the T-con board and the power source. Now they have failed for good.
Since the screen is defective this tv is effectively dead : try to sell it for parts (ask less than 75 pounds for it) and buy yourself a new one.
Jun 03, 2011 | Televison & Video
I have a Dynex DX-LCD32-09 TV it was fine last night when I turned it off. When I turned it on today it showed the channel number then the screen went black but I have sound on all channels. Is there a...
LCD tvs come with a florecent tube that projects light through the LCD screen like a stained glass window. It can be replaced if you take it to a repair shop that can order the parts. Given that it works and then turns off would obviously mean the bulb is working, the power is just getting cut to it at some point. This will complicate the repair considerably. I would just replace it, personally. By the time the diagnostic fee and the parts+ labor is done, you might as well just pay a little bit more for a brand new tv with better features and a new warranty.
May 25, 2011 | Dynex DX-LCD32-09 LCD TV
Red line on TV screen.
The LCD panel is defective...sorry I have to give you bad news.
May 13, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Red lamp lite flashes along with power light.......
That is definitely the Light Engine (also referred to as an optical block) Very expensive.
Dec 31, 2008 | Sony KDF-E55A20 55 in. LCD Television
Dynex DX-LCD37 TV Logo
108 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
