Question about Acer Ferrari 4000 Notebook
No display jus beeps
My acer ferrari 4000 has no diplay when powered up, emits 3 beeps, 4 beeps then 3 beeps, power light still on.
Nothing on the display.
  • 3 more comments
  • Anonymous Dec 20, 2007
    POWER ON AND WHITE SCREEN COMES UP AND EMITS 3 BEEPS NOTHING ELSE HELP!!!!!
  • racecarbry May 31, 2008
    Acer Ferraro 4005 with no display and same beeping pattern as described by acermike. I've been dealing with this problem for a while and the company has never been able to fix it (after 6, yes I said SIX, returns to the factory).
  • Anonymous Jul 13, 2008
    switch on notebook power on keyboard mouse ,but no display on screen if i plug a crt in there is display on the screen
  • brink0949 Oct 02, 2008
    After 4 years of working fine, this same problem has popped up on my 4000 as well.
  • tron80 May 05, 2009
    i've the same problem on acer ferrari 4005 : 1 long beep and 2 short with black screen after reboot from hd hibenation... i think the mainboard don't find the screen.
    i've changed for factory return : mainboard, hd, 2 lcd, power board... the beeps still
I had same problem most of the time when evr i opened my ferrari 4000 to clean dust. try removing ram and putting back then power up..it always works for me but after few tries from one slot to another. also remove hdd and again attach.
Posted on Apr 19, 2009
    Sergeant:
  • 457 Answers
Your memory chips must be had i that sounds like a chip problem under the laptop secured by two screws will be where the chip lodged pull it out and re-enter it might go it might not but that your problem I am sure of it.
Posted on Oct 10, 2007
SOURCE:
4 Beeps on my Acer X1935 and then nothing, no display
maybe you check on Rams, sometimes BIOS battery
Nov 11, 2012 | Acer Computers & Internet
How do i power up my acer ferrari 4000
Remove main battery and try again, if nothing! check power adapter for correct voltage, If okay! sub out the ram memory one at a time and test, still no change! the DC jack is often the source of trouble and the laptop will need to be dismantled down to the motherboard level, the DC jack will probably need resoldering.
Apr 14, 2012 | Acer Ferrari 4000 Laptop Notebook
Acer Ferrari 4000 power up with blank screen, no
If you cannot "press DELETE to enter setup", then it's the motherboard, or the battery, or the AC power-supply that has the problem.
Since it's likely that at least one of the battery and the power-supply are working, it's probably the motherboard (or the CPU on the motherboard) that is failing.
Take the computer to a qualified technician.
Replacing the CPU is possible, and is not very expensive.
Replacing the motherboard is possible, but is very expensive
(a few hundred dollars for a replacement motherboard, plus $100 for the technician's time to disassemble/replace/reassemble).
The only "good" news is that your files on your disk-drive probably are intact, and can be read and transferred to a new computer.
Of course, you can try to sell the "dead" computer on eBay, so that somebody else can "frankenstein" your computer with their computer, to combine two dead computers into one working one.
Nov 11, 2009 | Acer Computers & Internet
Need to find a power/battery charger board for Acer Ferrari 4000.
Hi there.
You will be able to get the laptop powerboard from ebay or Sony themselves, although if you get from Sony it will be considerably more expensive.
Good luck and thanks for choosing FixYa!!
May 28, 2009 | Acer Computers & Internet
My acer travelmate wont boot just beeps 4 times i recently reinstalled XP Pro os on acer ferrari 4000 and have recieved this same problem 4 beeps and black screen.won't boot..bios or os. HELP
I long + 3 short beeps or 3 short + 1 long beeps indicates memory problem.
The RAM module/s may need reseating to re-establish proper electrical contact.
If it still doesn't boot up then :-
Get the RAM module/s may be faulty, test the module/s in another laptop or get your friendly computer shop to test them.
May 07, 2009 | Acer Ferrari 4000 Laptop Notebook
Acer 8100 Travelmate - blank screen
Acer Ferrari 4000 "power on" blank screen, fan is running but no beeps, no activity in/from the HD. No reaction on a F8 start up (no Bios set up). It charges the battery OK.
KR Steen Larsen
Dec 08, 2008 | Acer Ferrari 4000 Notebook
Canon bj 4000
1: Unplug Power Cord
2: Hold POWER and FF and Print Mode buttons
3: Plug in Power Cord
4: Release after the beeps
Aug 21, 2008 | Canon BJC 6000 InkJet Printer
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
514 people viewed this question
Ekse
Alun Cox
