Hi, im working in a electronic shop but is still training. Im currently working on a 42inch lcd tv (Lg). Half the screen has picture and other half has stripes. When i twist the screen or tap on the edges lightly the lines go away. By the way its on the left side. I unscrewed the whole tv, and made sure the screen is tight and closed it up again. Still the same. Please help as the tv has to go to the client today. Many thanx.
  • 794 Answers
No need to go into panic mode. Since you work in an electronics repair shop- I'm sure they have repair manuals for LCDs. Review and apply the troubleshooting steps required to diagnose the problem you presented to this forum. In absence of any manuals, call the manufacturer's tech support hotline for repairmen or technician's- they'll guide you in repairing the problem. And certainly there is no shame in going to your boss and explaining your inability to fix the problem; after all you are still in training and no one would or should expect you to be ready to handle every problem that's put on your work bench.
This is all part of the learning curve- you'll gain the admiration and respect of your co-workers and boss for doing so. Don't try to bluff your way around it; who knows, this may also be a test of character and honesty.
Posted on Nov 26, 2013
snakehead
  • 1074 Answers
SOURCE: Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Posted on Jul 25, 2008
MNfisherman
  • 11896 Answers
SOURCE: LG 42
One of your system boards is failing. Possibly the "Y" convergeance board. The LCD Capacitors will most likely have to be replaced.
Posted on May 05, 2009
SOURCE: I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Posted on Feb 05, 2010
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
Posted on Mar 22, 2010
  • 8457 Answers
SOURCE: when my LG 42inch LCD tv is off for a while and
This problems it is the causes by the board that call the T-CON decoders board,this board sit at the bottom in the middle of the LCD screen panel.This T-CON decoders board is started dying to causes these problems or the fibers opotic cable connections is loses or frail damges to causes slightly signal tranmittion from the T-CON decoder board to the LCD screen panel.Just used the tv,when the problems is there for good.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Posted on Jan 27, 2011
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Im only getting half a picture
most LCD sets use two boards (or one with both in it) for this, one drives half the screen and the other the other half.
Possible bad board or bad connection where the board connected to the panel===that would be the worst case as the display which is called a panel could have a issue inside which is fatal costwise.
Nov 06, 2012 | Vizio 42 in. LCD TV
Only half screen working
LCD sets commonly use inverter boards--two which each drive half the screen for a picture---
Google the model number with "parts" to see a possible list of them--Shop Jimmy is a good source for this type of information.
May 27, 2012 | LG 55LD520 55 in. HD Ready LCD TV
When we 1st turn on the tv the left half of the screen is black right down the middle of the screen,,,,then 15 mins or so it starts to slowly regain strips of color and finally it has a full picture! Then...
When tv it does have a full picture,the tv it work ok?Yes,tv it is repairable.This tv problems are only have two possible electronic boards causes.1 the tv board that call the T-CON decoders board it is dying,this board sit in the middle of the bottom of the LCD screen panel,it control and decoding all the picture dots pixels before it gose into the LCD screen panel.2 worst cases the main board the tv Tuner signal board is it dying,this board control everythings.Like it take in the outside incomming signals sources,like the tv incomming broadcasting signal cable wire and all the external electronic unit divices plug it into the tv.80-90% this tv problems it is the causes by the tv T-CON decoders board only.Tries websites like Shopjimmy.com,Ebay.com to buy a reburbish T-CON decorders board and the tv main board Tuner signal board for the replacement.
May 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Have 42 inch LG flat screen...for about 3 years...
Take the back off with no power connected..You should have 2 invertor pcbs..one on the left and one on the right..well the side of the picture you cant see is the same side of the faulty invertor..replace this and this should solve the problem.it is the cheapest option..if not..im afraid is is a new LCD screen unless you are prepared to take it appart and replace backlight bulbs :)
Oct 17, 2009 | LG 42LC2D 42 in. LCD HDTV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Top half blank
It could be damage to the lcd screen or the back light if its the backlight it can be replaced but if its the lcd then im afraid its a replacement of the entire screen witch can cost over the amount of the tv
Apr 07, 2008 | LG 32LX1 32 in. HD-Ready LCD Television
Uhhh I broke my 42 in lcd lg tv on xmas
Ouch, sorry to hear that. I'm afraid there is not much you can do. If you have no warranty plan from the retailer that covers such incidents, you will have to get a quote from a repair outfit. However, my guess is the cost of repairing such damage would not be worth it.
Dec 26, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
