Question about Fluidmaster 400A Toilet Tank Repair Fill Valve
Fluidmaster fil valve float sticks
Will stick in the up position and not allow the tank to fill
  • 2,113 Answers
Give it a slight turn to stop it from rubbing on the side
Posted on Nov 26, 2013
Fluidmaster
First shut water off at stop than flush all the water out of the tank next take a sponge and get all the water out of tank next unsrew the supply line from the valve under tank than move out of the way next unsrew the nut on the valve of fluidmaster than pull the fluidmaster out of tank stick the new fluidmaster in tighten nut srew the supply line back on turn on stop and let the tank fill up thats it if the fluidmaster dont shut off press the handle let some water out and adjust the fluidmaster screw Tip the water should stop a 1/4 inch below the flush valve tube in center of toilet
Jul 11, 2016 | Fluidmaster Plumbing
300. Why does it occasionally get stuck in the up position or fails to refill tank completely?
It has been my experience that they are reliable. Fluidmaster instructions say to flush the valve (not the toilet) after installation to purge debris. It may be necessary to do this again. Also check for interference with the refill tubing. The float and linkage should be able to move freely.
Oct 10, 2012 | Fluidmaster Fill Valve and Flapper Repair...
My fluidmaster 400 anti siphon for toilet will not stop filling making pump run over and over
Hi turtlerose07...
Sounds like you have one or two problems with the fluidmaster 400.
1...The float is set too high allowing the water to overflow into the overflow pipe and allowing your pump to run too much.
2...Flapper valve inside at the bottom of the tank is not sealing properly, thus allowing water to leak and causing the fluidmaster to keep trying to fill the tank with water and causing the pump to run too much.
Please take time to rate me
Aug 24, 2011 | Home
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
I replaced my fluid master and now it will not stop filling in the tank.
Try lifting the float part of the valve. If the water stops filling, reset the float level lower.
If water does not stop when lifting the float, flush out the valve according to the instructions - steps 12 - 15.
12. IMPORTANT: Always clear sand and rust from system. Make sure
water supply is shut off. Remove valve TOP by lifting arm and rotating
top and arm 1/8 turn counterclockwise, pressing down slightly on cap.
13. While holding a container over the uncapped VALVE to prevent
splashing, turn water supply on and off a few times. Leave water
supply off.
14. Replace TOP by engaging lugs and rotating 1/8 turn clockwise. MAKE
CERTAIN TOP IS TURNED TO THE LOCKED POSITION. VALVE MAY
NOT TURN ON IF TOP IS NOT FULLY TO THE LOCKED POSITION.
15. Turn on water supply. Adjust water to desired level by squeezing water
level adjustment clip and moving FLOAT CUP up or down along stainless
steel link. Check for leaks, then check for proper flush.
If valve continues to run:
IF FILL VALVE WON'T TURN OFF,
• There may be debris at seal - repeat Steps 12-15.
• The seal inside the valve top may be damaged -replace with genuine
Fluidmaster 242 seal.
Nov 29, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
Fluidmaster 400 The Float get stuck in the Up position & doesnt allow the Tank to fill
Have a look at this link. Does it seem that the float does not ride smoothly along the valve body? Here is a troubleshooting guide for that peticular model. I hope it helps.
http://www.toiletology.com/troubles.shtml
Nov 24, 2010 | Garden
Fluidmaster S2DBL the stopper sticks up position who do I fix this.
If you're talking about the fill tube sticking in the latched position (not dropping), it's probably due to a sticking flush cable. Call Fluidmaster and they'll sen a replacement part.
Jul 15, 2010 | Dishwashers
Removing arm on#88592 to stick thru side of tank
If you are referring to the flush knob, the nut is reverse threaded. Remove the nut, then swing the arm to the left, and pull straight out of the tank.
Dec 23, 2009 | Fluidmaster Plumbing
Fluidmaster 400A Toilet Tank Repair Fill Valve Logo
247 people viewed this question
Top Fluidmaster Home Experts
john h
Are you a Fluidmaster Home Expert? Answer questions, earn points and help others
