Question about Nokia N70 Cellular Phone
SIM CARD REGISTRATION failed, N70
When I insert the sim in to the mobile and switch it on, it says SIM CARD REGISTRATION failed
  • 4 more comments
  • Mkhosani May 08, 2009
    HI Zohail
    I tried that and it still does not work. It seems there are lots of people with similar problem. What is the major course of this problem??? Any other possible solution?
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    ok try to reset ur phone like this first ok dont worry it will be solved
    + To restore your phone to the original factory default settings, press
    the Menu button, then go to Tools, Settings, General, Factory settings.
    Here you need to enter the lock code (generally 12345). After the
    reset, the device may take a longer time to power on.
    + To hard reset/format Nokia N72 (all data will be lost), follow the below mentioned steps:
    1. Turn off the mobile phone.
    2. Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3? button.
    3. While holding these three buttons, press the power button to switch on the device.
    4. Release your fingers when the screen displays the Nokia Logo and the language selection menu further.
    or try this
    Master reset
    1) *#7370#, then enter 12345 (This is the default security code unless the user has changed
    it) and then Yes. The phone then wipes all apps and phonebook contacts
    on the internal memory.
    One shud work or all
    let me know if doesnt work
    if after RESET again same problem then ur Network Sim Card Slot is faulty it the IC concerned is faulty but it is not a major repair thing very cheap but pls check all first and also before any hardware repairs pls update ur phone firmware from www.nokia.com
    download the Update Application and drivers for ur phone and install and conenct to internet and get the latest Firmware for ur phone if it dosnt help then go for hardware repairs
  • Shoaib Rais
    SIM CARD is not working get another one for testing otherwise get a piece of paper or something and make a packing above the sim card when u place it in slot to check the loosening of sim card sometimes
  • azam
    azam Dec 08, 2013
    2334795545
  • Anonymous Mar 17, 2014
    SIM CARD REGISTRATION failed, samsung rex 60 When I insert the sim in to the mobile and switch it on, it says SIM CARD REGISTRATION failed
  • Anonymous Mar 30, 2014
    it seems blocked
    Scholar:
  • 106 Answers
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
Posted on May 08, 2009
  • Yaqoob Khan
    Yaqoob Khan Sep 30, 2014
    hey, but mine issue is somewhat different for my nokia n70-1. I disassembled it and washed it with ctc and then assembled after fifteen minutes sans hot air. Now phone is does not show signals.
    New Friend:
Phone for nokia 2700
Posted on Jul 28, 2013
Phone says sim card registration has failed
When the message sim card registration failed comes up it is usually as a result of one of 2 things the first being that the phone has not recognized the sim card due to an improper fixing or the sim card has become faulty. Simply try the sim on a different mobile device to determine if the sim card is still good.
Thank you for visiting FixYa.
Hope this solution has been helpful?
Jul 10, 2011 | Nokia N73 Cellular Phone
Nokia 5800. sim card registration failed
try to insert your sim to other mobile then try balance inquiry after you have recieved the message turn off your mobile, remove the sim card and insert it again to your nokia 5800.
Aug 03, 2009 | Nokia 5800 XpressMusic Smartphone
My n70 phone is block
switch off phone just put out sim then switch on then show off line mode select no after switch off put sim then start
Feb 22, 2009 | Nokia N70 Cellular Phone
Unlocking code for nokia n70
(First: copy all contacts from the phone to SIM card)
1.Switch off the phone.
2. Press and hold the following three buttons:
Green(call answer) button, (*) button, (3) button.
3.Now press the switch on button.
4.Then the message 'Formatting" appears on the screen release all buttons. I hope this can assist you in the fix .
Sep 05, 2008 | Nokia N70 Cellular Phone
Nokia N70 insert sim card problem
u have to connect ur mobile with ur computer and make it flash set Sim Lock Intialise.
Jun 10, 2008 | Nokia N70 Cellular Phone
Sim card registration failed
Try another sim or other network provider.Good luck!
May 23, 2008 | Nokia N70 Cellular Phone
SIM card registration failed
i have the sme problem
Feb 25, 2008 | Cell Phones
You might have filled up the memory to the brim and the phone doesn't have enough to switch on.
Try reformat to original settings. anything you stored on the phone will be lost.
How to reformat your phone, first turn it OFF. Press * 3 send at the same time and keep them pressed while you turn the phone on.
Give it time to work.
Remember, do not let go the 3 keys until you see the formatting screen.
After a few minutes when the process is over, your Nokia N70 will be back to the original delivered system.
Jan 03, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
2,406 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
