Question about Carrier Weathermaker 8000 Gas Furnace 125k Btu
Furnace keeps shutting down - Carrier Weathermaker 8000 Gas Furnace 125k Btu
    Genius:
  • 1,198 Answers
The only thing I would fuss with on a furnace is the optical sensor that checks to see if there is flame. It would be a metal tube sticking into the combustion chamber, with a lens inside, or a flat black plate near the igniter. The lens can get sooted, need to be cleaned off.
Otherwise, it's a service call to check the gas control coils.
Be real careful not to touch the igniter, it is super delicate.
Posted on Nov 26, 2013
Bryant 345mav furnace shuts down early after one minute
Try to jump pressure switch as soon as the inducer come on and see if it stay longer. if it does you might have problem with draft or pressure switch itself defected.
Nov 28, 2013 | Heating & Cooling
Thermostat keeps shutting down a/c system
A couple questions. Have you ever tried switching from auto-on while the system was working properly? And when it shuts down, does the blower in the furnace/air handler shut down as well? And the no batteries just means the thermostat is drawing power from the transformer in the furnace.
Apr 17, 2013 | Heating & Cooling
Trane XR80 Furnace won't stay running
It sounds like your flue work in your main problem get this fixed first then see how it runs , pipes should run all the way out of the chimney .
Jan 23, 2013 | Heating & Cooling
My Payne furnace is NOT producing the desired heat anymore. Any ideas?
Hello, it could be shutting down on it's high limit switch due to a dirty air filter, dirty blower wheel, weak blower motor. Usually this would cause the furnace to shut down before it reaches the desired temp.
Dec 30, 2011 | Heating & Cooling
Our furnace keeps shutting down soon after burner ignites inducer motor stays running wont heat until reset switch behind inducer motor is pushed
Sometimes a "Flame Sensor" gets carboned up and does not detect that the furnace has ignited, so it shuts down the fuel source. Might try cleaning that if so equipped.
Dec 05, 2010 | Goodman GPG152407041 15 SEER Packaged...
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
The furnace won't stop at the programmed temperature set ponts
this is called a swing tempature it is desined to improve the eficincey of the frnace because it take less energy to run an hour in a three hours then 3 bursts of 25 min in a three hour period
HOWEVER if you do not like this you can usualy set the swing temp
Jan 16, 2009 | Hunter Fan Company 5/1/1 Programmable...
Carrier Weathermaker 8000 Gas Furnace 125k Btu Logo
78 people viewed this question
Top Carrier Air Tools & Compressors Experts
Tom Chichester
ray gallant
Are you a Carrier Air Tool and Compressor Expert? Answer questions, earn points and help others
