Question about Freestyle Shark Predator Wrist Watch
Take battery out of freestyle watch - Freestyle Shark Predator Wrist Watch
How to change battery shark 88 freestyle
  • Remove back
  • Locate battery and identify type. Note battery mounting arrangement for later reference
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Install back
  • Set time, etc.
Sep 05, 2016 | Freestyle Shark 88 Watches
What battery do I get for a freestyle 816 shark tide watch
the same one that is or was in it any good jewelry shop will change it free if you buy the battery there even WALMART
Mar 26, 2015 | Freestyle Watches
What size battery for shark x
If you or a local jeweller changes the battery your warranty will be voided. It is best to send your watch to Freestyle service center in Long Island City because a local jeweller might not reseal your watch properly compromising the water resistance capabilities.
Warranty/Service:
Freestyle U.S.A.
47-14 32nd Place
Long Island City, NY 11101
Phone: 800-874-0907 ext: 222
Dec 28, 2014 | Freestyle Watches
How to change battery in freestyle ultrashark 91101
You probably can't. This is a diving style watch and has a screw on back which requires a special tool to remove. Go to a bonafide watchmaker, pay the man, get it done right!
Nov 01, 2011 | Freestyle Ultra Shark #91101 Watch for Men
Battery? or can any jewlry/watch repair shop fix?
mcdevito75 here Best Bet, look for a small watch repair shop in yourarea, most likely you need a battery or even better, loosened the one already in the watch.
Jul 02, 2010 | Freestyle SDI I Wrist Watch
How do i get the back off to switch the battery off my freestyle cortez watch
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 nay watch or jewelry store can change the battery and renew the gasket for you.
Apr 12, 2010 | Freestyle Cortez Mid Watch
Battery replacement - Freestyle shark watch
I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
Jan 30, 2010 | Freestyle Shark X 75036 Wrist Watch
My freestyle model 798 is contantly resetting itself back to Jan. 1 12 am. Is this a battery problem?
No, this is not a battery problem. Use your users manual and read how to reset time and date.
Jan 12, 2010 | Freestyle Watches
What is the correct battery for my freestyle model 750
The manufacturer does no recommend that you replace batteries yourself (presumably to ensure that it retains the waterp.roof seal)
See excerpt from their web site support.
"Do not attempt to repair the watch yourself. It is strongly recommended that a certified jeweler, watch repair technician or Freestyle service center replace your battery. This will help in preventing water leakage from improper battery replacement, which is not covered in your warranty. "
Dec 27, 2009 | Freestyle Shark Buzz Wrist Watch
I have a square Freestyle watch. It keeps beeping, can't trn off
You can try taking the battery out and waiting a minute or two then replace but you should probably have a watch maker/technician "AC" or clear the watch. This involves resetting the circuit board and only takes a moment. I would also have them reseal the watch and pressure test it as Freestyle's are made to be in water and you will want to maintain the water resistance.
Sep 17, 2009 | Freestyle Shark Predator Wrist Watch
Freestyle Shark Predator Wrist Watch Logo
27 people viewed this question
Top Freestyle Watches Experts
ray gallant
Are you a Freestyle Watch Expert? Answer questions, earn points and help others
