Question about Essick Air Humidifiers
Ff error code on a 697-500 series essick humidifier
The fan has quit running and the digital code is FF.
4 Suggested Answers
SOURCE: I own an Essick Air Products Humidifier Model HD
had to order mine from the company by calling 18006543545 part #509229-1 Cap, Valve assembly
Posted on Dec 07, 2010
  • 381 Answers
SOURCE: I have an Essick air
Here is a solution I wrote up for another Humidifier with a fan problem:
Have you considered checking to see if the fan motor mightjust need cleaning and lubricating?
Most small fans and heaters, have small fan motors, in which thebearings have dried out over the years. If you have made anelectrical check on the motor leads-- and you have electric going into thewindings, likely the motor feels warm? (If not-- possibly a bad splicewhere the supply wire attaches to the tiny armature wires?-- check , and checkcontinuity)
If you want to tear into the fan motor, and clean up and lubricate thebearings-- here are some tips:
First you need to get inside the heater of the fan housing-- by removing theprotective covers.
Note the screws, s, locations, and how the protective coverswill go back on when you are ready to reassembly-- Mark where the screw holesare that line up with the matching other parts.
Then remove the motor from it's bracket (Possibly have to remove the fanfirst?)
You will have to remove the fan, to lubricate both front and realbearings.
Next you will need to remove the 4 long screws that hold the motorframe together-- Be sure to mark the original alignment, so you can reassemblycorrectly.
Now, with the fan removed, gently separate the Front and rearhalf's of the motor. Usually the windings will stay with the portion ofthe motor where the wires are still attached. Either way, you are goingto have to get the bearings to slide off both Shafts of the armature-- withoutbreaking the delicate winding wires-- the wires are hair thin on small motors!
Now clean up the caked on residue on the shaft where the bearings ride,with rubbing alcohol. Clean up the internals of the bearings as best youcan- making sure the pores of the oil-lite bearings are not plugged withsolids. Now begin the gentle process of getting the bearing wicking tosoak up new oil. When you are sure the reservoirs are wellsaturated, then generously lubricate the shafts, and slip them thru thebearings again-- retracing all your steps above, The motor shaft shouldturn freely now. You can test the motor without the fan on-- to besure you have the motor itself reassembled properly.
Double check all the splices, switches, and any high temperature limit switchesfor continuity-- and trace the wiring all the way back out thru the powersupply cord.
What did you find, and what do you need to do next?
I hope this helped-- Let me know If I can help further--
Mack B
Posted on Jan 26, 2011
SOURCE: We have an Essick Humidifier
That stands for "change filter."
Posted on Mar 04, 2011
New filter, not running and leaking all over
Customer Reviews: Essick Air 821-000 Digital Control ...
www.amazon.com/Essick-Air...Humidifier/.../B0000D...
Amazon.com, Inc.Essick Air 821-000 Digital Control Evaporative Console Humidifier ... Holds 6 gallons and will dump 6 gallons in to the air over a 24 hour period, which ... a pain to fill, eventually leak, or come defective from the factory (holes on seams). ... We left itrunning all night, and barely any water had evaporated by the next morning.
www.amazon.com/821...Humidifier/.../B0000D8EJZ?...
Amazon.com, Inc.Essick Air 821-000 Digital Control Evaporative Console Humidifier ... So although notas dry as the northeast, it gets dry when the temps go down. ..... Had this humidifierfor less than three months and it started leaking all over my hard wood ...
Jan 05, 2016 | Essick Air Humidifiers
Changed wicks and change wick light is still on. how to reset?
Humidifiers - Frequently Asked Questions - iAllergy
www.iallergy.com/humidifier_answers.html
Do I need to replace filters, and if so, how often? ... quietest humidifiers available, and the ideal choice when noise level is a concern (if you are a light sleeper). ... Most evaporative cool moisture humidifiers use replaceable wick filters, and these should bechanged every 2 months on average (wick filter life varies depending ...
[PDF]OWNER'S CARE & USE MANUAL - Appliance Factory Parts
www.appliancefactoryparts.com/content/pdfs/116710-1.pdf
Refill light with Automatic Shutoff. • 2-Speed Fan ... If it still does not fit, ... Thishumidifier is ETL listed with Essick Air brand evaporative wicks in place. ... wick, the water evaporates into the air, leaving behind any white dust, ... We recommendchanging the wick ... Use only Essick Air brand replacement wicks and chemicals.
Amazon.com - AIRCARE 1041 Replacement Console Wick ...
www.amazon.com/...Replacement...Wick/.../B0002GD...
Amazon.com, Inc.AHAM certified output; Longer lasting, still at 96-2/5-percent after 90 days; Less energy consumption ... Essick Air 1970 Humidifier Bacteriostatic Treatment, 1-Quart ... BestAir CB41 Essick 1041 Replacement Wick Filter ... Super Wicks trap minerals and other particulates to prevent white dust and sprays, which are often seen ...
Jan 04, 2016 | Humidifiers
Just bought this humidifier yesterday -- cannot even get the fan to turn on....
Check that the light switch is on for that plug socket. Keep the receipt, its probably defective. Take that POS back to where it came from
Jan 22, 2011 | Essick Air ED11800 Humidifier
The fan is loud and the motor is running "hot". Is there a place to oil the fan's motor?
This is a sealed bearing motor so there is no oil ports. You can blow out with compressed air and spray motor shaft with WD-40. Be careful not to spray any lube inside motor. If you can get to them blow out motor cooling ports .this should help motor run cooler and quieter. Hope this helps you. Thanks
Jan 02, 2011 | Essick Air Credenza 696 400 5.2 Gallon...
Humidifiers Logo
75 people viewed this question
Top Essick Air Humidifiers Experts
Mack Baxter
Joseph Mueller
Joseph Mueller
Rabbit Brains
Rabbit Brains
Are you an Essick Air Humidifier Expert? Answer questions, earn points and help others
