FixYa.com
Tags:
Haier HVT12ABS Compact Wine Cooler
HAier HVT12ABS wont turn on (by 2 users)
posted by cowens on Oct 10, 2007
the unit was working fine and now is dead.  I pulled off the plate in the back and it looks like there are two fuses on the back board and the top one looks black.  can I replace this fuse
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Atticdweller, posted on Nov 21, 2007
I had the same problem, and when I looked the bottom fuse is blown on mine as well. My only problem is that I don't know where to find any prints which tell me what is downstream frtom this fuse.
Best Solution
posted on Oct 30, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I too experienced this problem. The upper fuse that you refer to is the 120V AC line fuse. The lower fuse is for the internal 12VDC supply (5A). These fuses are pig tail types and are soldered into the circuit board. The 12VDC fuse was blown on mine. After some cursory troubleshooting, I replaced the fuse, and off she ran... for about 12 hours and the fuse blew again.  It's not worth fixing.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 11, 2007
Helpful (85)
fridgetech
Rank:Guru Guru
Rating: 88%, 711 votes
Haier doesn't list a fuse.  That board would need to be replaced if it is the problem.  I would say the most common problem on those is the thermostat if the board doesn't fix it.  You might see if that fuse will pop out and test it for resistance first.  If it does come out you might be able to find one at a hardware store that will fit and see if it starts working again.  I looked at http://www.partsquik.com/scripts/realtime.live/InvLookup/haiermsearch03.p
Solution #3
posted on Feb 06, 2008
Not Rated (0)
EmgSupport
Rank:Master Master
Rating: 87%, 9 votes
That board is available on there for $27. RF-1870-01 is the part number in case you still have the unit..
Can you Help with these Refrigerators problems?
WINE COOLER
where might they be located i... Answer This...
Haier HVT 12ABS fan runs, but...
We've had this wine fridge for... Answer This...
my wine cooler does not cool
any ideas on fixing this... Answer This...
I HAVE THIS NOW FOR
i have this now for about 6... Answer This...
won't turn on
unit was working fine, but now... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
