Question about Arietta 30 in. Wall Mount Decorative Range Hood Dekor Glass 30
Light bulb I can't find a 40w bulb to replace a burnt bulb. Any ideas?
The microwave is working, but the light doesn't come on. can it be changed if blown?
yes. bulbs of microwave can be replaced.
Mention your brand/model/size and someone can help identify the right bulb and procedure to replace yourself.
See below an example Microwave Repair Replacing the Internal Light Bulb 40W Whirlpool Part...
Apr 15, 2016 | Microwave Ovens
JJW9527BAQ change light bulb
40w appliance light bulb.
Jan 12, 2012 | Jenn-Air Ovens
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
Jan 11, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Hi, I have a GE Profile oven that needs a light bulb replacement. It is NOT a standard 40W appliance bulb as stated. What bulb is it?
What is the model number for your oven reply with it and i will give you the GE part number for that light bulb
Sep 17, 2011 | GE Profile JTP18 Electric Single Oven
Two different size ultraviolet ballast. The .71AMP ballast feeds two 40W ultraviolet ''UV'' bulbs. The .37AMP ballast feeds one 40W ultraviloet bulb. The two light to larger bal;last want come on. The...
I usually test the ballast simply by excluding everything else.
1) Put in bulb that you know works
2) Replace starter (if you have one)
3) check that wiring is intact (sounds like it is for you but I had one light that the wiring barely made contact so sometimes it came on and sometimes it blinked)
4) If all that is good, then it's probably the ballast.
Sep 29, 2009 | Garden
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
40w candleabra bulb blew now can't turn lights off with remote
There is a receiver in the fan that when the light blew might have damaged that part of the receiver. I think you can buy them,but you will have to get into the base of the fan(ceiling cover).
Jan 02, 2009 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Light bulbs
fan may have a lot of vibration. or the MAGNETRON is kicking back a jolt. or your slamming the door too hard.
May 12, 2008 | GE JVM1660 Microwave Oven
Kenmore refridgerator 78285892 Freezer light won't work
probably a bad socket. 10-12 years old metal would not likely to last inside a freezer box.corrosion could have eaten the metals...
Feb 11, 2008 | Refrigerators
Arietta 30 in. Wall Mount Decorative Range Hood Dekor Glass 30 Logo
81 people viewed this question
Top Arietta Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an Arietta Kitchen Range Expert? Answer questions, earn points and help others
