Question about Lexmark Z645 InkJet Photo Printer
Lexmark z645 printing blank pages z640 18k6400
Printing blank pages
SOURCE: Lexmark x1185 printing problems
my lexmark will not print in color
Posted on Jan 30, 2008
mediatecar
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
jazzyboy11
  • 728 Answers
SOURCE: Printing Blank Pages
Try checking the ink cartridges and make sure they have ink in them or it will keep printing blank pages. Then try printing a test page by going to control panel, clicking on printers and faxes and right clicking on your printer and going to properties. Then go all the way down to the bottom of the page and click print test page. It will clean the printer cartridges and align them to print correctly. It should work after that.
Posted on Nov 08, 2008
SOURCE: Lexmark 1290 on Vista Printing Blank Pages
Fond this on the Lexmark Website. Hope it helps.
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· 1) Disconnect your USB cable from your printer.
· 2) Uninstall all Lexmark printer drivers on your PC.
· 3) Download the correct Vista driver for your model.
· 4) While leaving the USB unconnected, Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Posted on Jan 14, 2009
Roop1980
  • 228 Answers
SOURCE: Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Posted on Oct 01, 2009
Testimonial: "Thank you. I was on the phone with Lexmark a whole hour last night and they couldn't fix it. This corrected the problem immediately! You are a Wiz"
Lexmark pro 205 printing a blank page before a document
If you're using Windows, try to follow these steps to fix the problem.
  1. Start menu > Printers & Faxes > Lexmark Pro200 Series Properties window pops up > go to Advanced tab > Printing Defaults.
  2. The Lexmark Pro200 Series Printing Preferences window pops up > go to Advanced tab > More Options > under Suppress Blank Pages, enable "Enable blank page suppression"
  3. Save the setting.
  4. Try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark Prospect Pro205 Wireless...
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
Lexmark Z645 can print locally, but will not print off of citrix
Lexmark X and Z series printers do not function in a Citrix environment, see page 4 on the following document.
ftp://ftp.lexmark-europe.com/brochures/de/solutions/citrix_basic.pdf
Apr 13, 2009 | Lexmark Z645 InkJet Photo Printer
Page is blank after printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Lexmark Z645 InkJet Photo Printer
Printing blank
Hi Aj91,
Have you verified that the cartridges of your printer are not empty of ink ?
Did you installed the correct driver for your printer ?
Sep 13, 2008 | Lexmark Z645 InkJet Photo Printer
Won't Print
I also have a Z645 and have had it now for almost a year...love it's performance but now all of a sudden it only prints certain things...duh! I don't know if any of you that have problems went to the sdolution center for Lexmark but on there ...there an upgrade to your printer, which is not is a section that says you MAY need to install an upgrade which sometimes corrects the problem UNLESS of course you do as I do with my "other" lexmark and they tell you that there no longer is any updates so in that case you are S.O.L....basically you need to buy a new printer......I am gonna call tech support tomorrow for my problem but getting the upgrade MAY help you others....good luck!
Jun 14, 2008 | Lexmark Z645 InkJet Photo Printer
Lexmark z645 printer
format computer and get the result
Nov 12, 2007 | Lexmark Z645 InkJet Photo Printer
Lexmark Z645 InkJet Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
