My tv has full picture for about two minutes thengoes blank the green light blinks then comes bak on and repeats the process
  • 28 Answers
You have to reset your tv.
If there is no reset button,then while the tv is on unplug the cord from the wall socket,this shouid reset the tv.Wait about 5 minutes before you turn it back on.
If this doesn't work then,your tv is about to go,unless you have a valid warranty.
Hope this helps.
Posted on Nov 26, 2013
4 Suggested Answers
  • 1153 Answers
SOURCE: tv does not turn on. Timer light blinks
First check error codes to do this search threads or goto ctechnicians.com
Posted on Dec 31, 2007
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
SOURCE: Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
Posted on Mar 21, 2009
55 " sony wega projection tv
Overheating? Check fans working near lamp
Dec 08, 2013 | Televison & Video
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Intermittent blank screen with r,g and b semi-circles at top of screen
the blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
Sep 09, 2008 | Sony KP-46V35 TV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Red/Green Light Problem
Had same problem after only 3 months, tech looked at it said had a power circuit problem causing it to keep cycling, they exchanged my TV. No problem since.
Oct 29, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
