Question about ESI Verezano PDVD-190B Portable DVD Player - 7 Wide Screen, 480 x 234 Reso
Verezano pdvd-190b reset password - ESI Verezano PDVD-190B Portable DVD Player - 7 Wide Screen, 480 x 234 Reso
I need a replacement for a rhine pl-190B
A PL-190B ceiling fan module is is a Wattage Limiter rated at 190W maximum. It is about 1" square and has a red, blue and white factory wired into the fan's light circuit in most cases. The AC power to the lights is run through the module to "ensure" no one puts more than 190W (about 2 amps)of light bulbs through the circuit for "safety" reasons. So four 60w bulbs and some CFLs will trip the module. These wattage limiters are sometimes feeding the fan motor in addition to the lights, however the units I have seen just control the "blue wire" going to the lights. Some suggest simply cutting it out and splice the blue and red wires (or blue and blue) that are left in the fan after removing out the module. If the module has two whites, wirenut them together separately. Otherwise just insulate or cap the single white.
At that point your ceiling fan and lights are like all others made before 2005 and depend on the circuit breaker and you to only use four 40w bulbs max in the fan. As indicated, some low wattage CFLs will also trip the module. Some internet sources have the PL-190B available for around $15.
Dec 31, 2013 | Computers & Internet
I need a replacement part for a rhine pl-190B
Dec 31, 2013 | Hampton Bay 24002 Ceiling Fan
Bush PDVD-312 not reading discs
remove the cover then look for a burnt parts like capacitor or a transformer or an stuck up in the loading tray.
Oct 14, 2012 | Televison & Video
How to increase contrast 190B
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Oct 25, 2011 | Philips 190B4CG (Gray) 19" LCD Monitor
We cant plays our DVD on PDVD.Doesnt works our PDVD.It shows an error code while we trying to play a dvd by using PDVD.Code is 80040216
Read the thread from forum.cyberlink.com - Error 80040216 Power DVD!
There are many free DVD software you can use, why use Cyberlink 'buggy' software?
If you are on a Windows OS platform,
Here are some free Players eg. VLC Player, MPStar Player or Windows Media Player 11.
Download the codec package and install either "K-Lite Codec Pack or K-Lite Mega Codec Pack" from http://www.free-codecs.com/index.htm. With these you should be able to play most of the Audio and Video formats.
Hope it helps.
Oct 08, 2010 | Computers & Internet
Имам PHILIPS 190B наблюдава и...
> PHILIPS 190B > I have seen many 10 seconds > a box appears saying account security FLAG NEW PLEASE > how to get rid of this Access http://www.ca.com/virusinfo and select to run an "online virus scan".
Nov 01, 2009 | Computers & Internet
ESI Verezano PDVD-190B Portable DVD Player - 7 Wide Screen, 480 x 234 Reso Logo
27 people viewed this question
Top ESI Televison & Video Experts
Are you an ESI Televison and Video Expert? Answer questions, earn points and help others
