Question about Dynex 32 in. LCD Flat-Panel HDTV
Tv fuse power
Help
    Top Expert:
  • Dynex Master
  • 74,377 Answers
The problem post of yours' have no details to provide a solution. Provide more details please. google.com/+GopakumarGopalan
Posted on Nov 26, 2013
TV has no power after power cut
Fuse inside tv or power supply most likely fuse
Apr 04, 2014 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Lecy blew tv wouldn't come back on change fuse in plug still no light on tv does 42" lg hd tv have a fuse internal.
Yes, TV's have an internal fuse on the power supply. All too often though more damage is caused besides a blown fuse or the fuse doesn't serve the purpose and the power supply is damaged. You can check and replace the fuse as necessary. If you need a replacement power supply, here is a list of vendors below. Have your TV model ready to help you find the part you need.
www.tristatemodule.com
Nov 04, 2013 | LG 42LC2D 42 in. LCD HDTV
Keep blowing the main fuse.
To which circuit section did you replaced the fuse? Main power retulator? Just understand, the fuses are used to protect the circuit and TV from any short circuit or over voltage. Without any one of these, no fuse will blow up. If it was due to over voltage, the set should work after a fuse replacement. But here, the fuse blow up again, means, there is some thing shorted component/s. Check which component is shorted, and replace it, before replacing an other fuse. One more thing to say is, never insert a fuse other than specified. The voltage and ampere specification to fuse, will be marked at the circuit board, very near to the fuse clamp. Insert a fuse of same rating only. Using other fuse, rated higher ampere rating, might make things worse.
May 27, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Where are the fuses in my tv
The fuse of your tv is located in the power supply if you remove the back cover of your tv you just follow the ac cord this ac cord is attach to the power supply and you will see the fuse there, this is the picture of a fuse.
hope this may help good day and best regards.
Sep 16, 2011 | Toshiba Televison & Video
WE HAD A LIGHTING STORM AND I HAVE NO LIGHTS ON MY BRAVIA WILL NOT TURN ON IS THERE A BREAKER OR FUSE TO LOOK FOR
There is a fuse in the tv power supply board,a fuse it is located near the a/c socket plug in of the tv power supply board.Lighting storm pack a huge anount of power and magnatic static field.If ur tv was in that path.U will not fixed it with a new fuse the tv whole power board probally dead already and those other circuit boards on the tv might be dead too.Good look with the replacement of the fuse,maricles might happen ur tv just have a dead fuse only.Not must take to or call many tvs shops and get the best estamates prices to fixed the tv.Not a do it self project,if tv a got hit by a massive power surges.
Aug 11, 2011 | Sony BRAVIA KDL-46V3000 Television
Tv at standby mode blown fuse fu120 2.5A.What next to do?
Unplug the TV from the power point.
Replace the fuse with the same value 2.5Amps
Do not put a higher value fuse in there because if there is a fault it may damage your TV.
When you replace the Fuse, plug the TV back into the power point.
If it works great, then it may have been a faulty fuse or power surge.
If the TV doesn't work then you may need a TV Technician to check the TV.
I hope this helps you.
If so please leave a vote or comment.
Have a Great Day
MobileJB
Jul 15, 2011 | Televison & Video
Technika LCD19id - No power to internal fuseMy LCD 19id-107 tv turned itself off and will not come back on. I have power to the 3 pin power connector at the rear of the tv. However i have no power to the...
I have a Technika 22 inc hd flatscreen that will not power up. you can here the dvd running if you load a dvd but the television side wont power up.I have tried to find the internal fuse but have had no luck.Anyone help?
Nov 15, 2008 | Televison & Video
TV will not work
Hello dnjmartz,
Your friend is correct there is a fuse in your televisions's power supply. Now I do not however suggest that you open the TV set and try to find it, because it's not like the old days where the fuse was located in or around about the same area in most TVs . The fuse in this case might be towards the middle of the set or on the power supply board in any location so finding the fuse will be the biggest chore. However here are some simple instructions of how you might be able to find the fuse.
1. unplug the TV
2 take the back off of the tv
3. using a flashlight look for a component that looks like two round metallic cylinders separated by a glass cylinder.
4. remove the fuse from the fuse holder
5. visually inspect the fuse for internal burning (black soot)
6. if possible test the fuse with an ohmmeter should read 0 ohms
7. Replace the fuse with one of the same voltage and current rating (check for replacement fuses at radio shack or some place like that)
8. After the fuse is replaced try to turn on the TV before putting the back on "BE VERY CAREFUL DANGEROUS VOLTAGES ARE PRESENT"
9. If the TV comes on you are read to turn the TV off and put the back of the TV back on.
10 If the TV does not come back on you will have to get the set looked at by a qualified TV technician since if the TV does not come on it may be the result of a power supply malfunction.
I hope this helps,
Thank you,
Shuttle83
Jul 14, 2008 | Orion1934 19" TV
I can't find fuse
TV fuses are always right near where the power cord plugs into the circuit board. Never seen a TV without one.
Feb 14, 2008 | Panasonic CT-32SL14 32" TV
Dynex 32 in. LCD Flat-Panel HDTV Logo
14 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
