Question about Jam Little Tikes Adjust N Jam Basketball - 616068
Little Tikes Adjust N Jam Basketball - 616068 instruction manual
Can't remove plug from base of little tikes totsports basketball
They ar PLUGS not screws, so turning them will not work. I used my flathead screwdrive to pry all around the base of the plugs to remove them.
Apr 14, 2012 | Little Tikes Totsports Easy Score...
We have a Little Tikes sports climber (the one with a slide, goal and basketball/netball hoop. We have lost the nut that fixes the basketball hoop to the climber. Any suggestions please?
If there is an identical nut attached to any other part of the equipment, remove it, and take it to your hardware store to see if they have a match, then put it back on after you find the new one.
Jun 02, 2011 | Little Tikes Swing Along Castle
I need a replacement net for our Little Tikes Basketball hoop
little tikes sells it on their web site
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=7865
May 23, 2011 | Little Tikes Totsports Easy Score...
My cooking creations kitchen didn`t come with an assembly instruction manual
Here is the link to download assembly instructions, though I did not see "cooking creations" listed, you may try entering the exact model number:
http://www.littletikes.com/consumerservice/little-tikes-assembly-instructions.aspx
Note, that Little Tikes does not post all assembly directions- some products do not have them online. However, if you contact them via this form, they can send them to you:
http://www.littletikes.com/consumerservice/Contact-Us.aspx
Just select "Product Help" from the subject field. Good luck to you, hope this helps!
Jan 09, 2011 | Little Tikes Toys
I need th collar lock assemby and a new ball. Please advise price and availablity.
Sep 11, 2010 | Little Tikes Totsports Easy Score...
How do i string the net
http://www.littletikes.com/pdf/4612 10_98.pdf
this is the manual for your item.
To lace the net, take top of each loop, slide it up thru each center hole and spead it over the two end pins.
See pics # 10 & #11
eNJOY AND HAVE A HAPPY HOLIDAY
Dec 12, 2009 | Little Tikes Totsports Easy Score...
Jam Little Tikes Adjust N Jam Basketball - 616068 Logo
46 people viewed this question
Top Jam Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Jam Toy Expert? Answer questions, earn points and help others
