Question about Kitchen Appliances - Others
Wiring dia 70-100 exide battery charger
I need a wiring diagram of an exide model 70-100 battery charger. The rate control switch is bad and I need to replace it.
2 Suggested Answers
  • 75 Answers
SOURCE: Car Battery Charger - Repair
thats what i did on mine they blew when i hooked the cables up backwards (gotta watch that)
but i used 130 amp alt diodes from an old tractor alt i had
Posted on Jul 03, 2009
Wiring diagram for Energizer battery charger chvcm
You will never find one for these products. I have worked on many an you just can't find them good luck
Aug 23, 2016 | Energizer Rechargable Battery with Charger
HOW TO REMOVE THE GLUE OF THE UPPER CAP COVBEWR OF eXIDE SAFE POWER SEALED LEAD ACID BATTERY 12VOLT 14.4/ WITH OUT RISK
don't remove the cover or open the battery
it is full of acid and is not to be messed with
you cannot fix any part of the battery so just replace it
remove the wire terminals from the battery and replace it with a new battery
Jul 13, 2016 | Exide Computers & Internet
Change exide fork lift battery charger from 240v tap to a 208v tap
Download the installation manual. It is too dangerous to explain the procedure on this site. You need a visual. Be careful and stay safe!
Feb 03, 2016 | Exide Computers & Internet
My rear wiper, defroster and licence plate lights stopped working on my 2007 suzuki swift but when I open the rear hatch the licence plate lights come on . Any ideas what's wrong?bad ground?
[PDF]Wiring Diagram.pdf - Ken Gilbert
ken-gilbert.com/wrx/mans/99.../Wiring%20Diagram.pdf
Each connector number shown in the wiring dia- ... Rear defogger cord (Ground). Fuel tank cord,. Roof cord, ... circuit. Then check the switch, relay, fuse, ground, etc. 4. .....Rear wiper motor. Rear wiper ... License plate light RH. Tail light LH.
#? license plate light - Circuit Wiring Diagrams
circuitswiring.com/tag/license-plate-light/
2008 Volkswagen Newbeetle Main Fuse Box Diagram 2008 Volkswagen Newbeetle ...Parts: rear window defogger, shift lock, battery positive voltage, interior light, A/C clutch, ... brake light, daytime driving light, wiper and washer system, vacan, fuel pump, central ... 1997 Suzuki Geo Tracker Left Dash Fuse Box Diagram.
#? license plate light - Circuit Wiring Diagrams - Page 3
circuitswiring.com/tag/license-plate-light/page/3/
Audi A4 Engine Fuse Box Diagram Audi A4 Engine Fuse Box Map Fuse Panel ... mirror control, wiper, washer, horn, brake light, cruise control, heated rear window, ... 2003Suzuki Aerio Dash Fuse Box Diagram 2003 Suzuki Aerio Dash Fuse Box ... rear defroster, fuel injection controller, radio, A/T controller, hazard light, ...
Jan 05, 2016 | Suzuki Cars & Trucks
Need wiring dia. for 117042 century
Century does not have downloadable owner's manual's unfortunately, however you can find similar models in Lincoln and Miller and find a suitably close wiring diagram. None will have the control board schematics normally.
Jan 08, 2012 | Century Welding Tools
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
Inverter not on
if your inverter is not coming on it is possible the power transistors that do the switching are bad and they need replacement
Feb 18, 2010 | Exide (FE020AA0A0A0A0A) UPS System
What battery should be used in the car?
It depends on which brand of car battery you prefer. You will get a range of different opinions on which brands are the best based on experiences with different brands.
If you are happy with the Exide brand then the battery selection depends upon which engine you have fitted in the car - the 2.2 litre or 2.4 litre. Anyhow here are some Exide models that will fit your vehicle. You need an Exide 75 size/model with the correct minimum CCA (cold cranking amps)
2.4 Litre engine - Exide 75 - 600 cold cranking amps
2.2 litre engine - Exide 75 - 525 cold cranking amps
Any large battery retailer will be able to help you select a battery suitabe for your car but many specialise in particular brands. Personally I prefer to select a heavy duty battery that is suitable for the vehicle and will offer more than the minimum required cranking amps.
Dec 06, 2009 | 2000 Pontiac Sunfire
Kitchen Appliances - Others Logo
131 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
