Another possible reason why your Kenmore Elite Oasis dryer model 110.67042600 won't start is because the door switch is defective. The door switch is located on the door of the dryer. To check the door switch: 1. Unplug the dryer from the wall outlet.
2. Open the door of the dryer.
3. Locate the door switch on the door of the dryer.
4. Use a multimeter to test the door switch for continuity.
If the door switch is defective, it will need to be replaced.
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part. If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
1. No power to the dryer Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
I bet you have a blown fuse. Fuse is located on the blowers housing near where the flex pipe hooks up. Clean out the dryer, open the vent to outside and replace this fuse:
