Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
My clock motor on amalibu ML600tw power pack died part gw1950. Where can I buy one?
ML600 won't turn off
The clock module for power pack is not sold separately.
Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.
Check outlet with circuit analyzer.
Try connecting power pack to another outlet.
Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 15, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
Where can I purchase a Model #pb912m10 timer for an intermatic transformer?
The PB912M10 clock module is not sold separately.
Open following links to see available clock modules.
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
If power pack transformer still works, it might be easiest to buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Open following link for power pack resources showing tips and warranties:
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
My ml600tw timer is not working. The unit has power, but the timer will not turn.
If the clock dial is not rotating, the clock motor has gone bad.
Easiest solution is set power pack in override so lights are on, then plug power pack into cheap plug-in timer.
Some people report being able to disassemble clock motor and add vaseline to gears to restore functionality. Other peole report not remembering how all the tiny gears fit back together.
My experience is that once motors slow down and overheat, they never work correctly again.
There are no replacement clock motors for power packs.
Open following link for power pack troubleshoot and resources and tips:
Jul 10, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
My ml600tw timer stopped working. How do you replace the timer? I took screw out by timer but I cant pull timer out. Is it held in another way?
You posted under Intermatic/Malibu ML series power pack.
There are no replacement clock mechanisms or timer modules for ML series power packs.
If you found a replacement clock motor source, add a comment add a comment here so others can benefit. If you find a way to repair clock motor, also add a comment.
Many people have same problem and will benefit from your discovery.
To work around problem, buy cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
ML series has 5 year limited warranty.
Open following links for troubleshooting resources, warranty links, manual links and Intermatic parts:
Apr 19, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Clock isn't running
Open following for Power Pack troubleshoot and warranty information and other tips to keep power pack working longer:
Upvote the help.
Sep 24, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
My 300 watt Malibu Power pack sticks and won't turn on automatically, but will go off automatically ok but it sticks trying to turn on
Open following link for ML power pack troubleshoot, plus tips to keep power pack from burning out, trippers and warranty:
If clock motor has gotten weak, then buy cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
Upvote the help.
Sep 02, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Just as someone else wrote, I too have the Malibu light timer and have the blue & red pegs set to turn on (red peg) at 7pm and off (black peg) at 11pm. The lights will not automatically turn on...I...
The clock motor has gotten weak and is now overheating, and will soon stop turning. There are no replacement clock motors for ML series power packs.
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
Upvote the help.
Nov 09, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
The timer on my ml600tw will not run. I do not hear it working although I have power and can trip the lights on if I turn the clock. Can you tell me what the problem is? Howard
If clock motor stopped working, set power pack to override, buy cheap plug-in timer, plug power pack into cheap timer.
Open following link for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
Upvote the help.
Oct 08, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
93 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
