Question about Garden
Looking for drive belt diagram for 20 hp 50'' cut 1998 yardking
Trouble putting back together,had to remove body and deck to get to belt system,no idea how to replace drive belt
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Get the model # up here and I can help. always remember that a v pulley accepts the v of the belt and the flat pulley accepts the flat side. I can almost see this in my head...
Posted on Nov 27, 2013
  • 37 Answers
SOURCE: Ariens sierra 1440G belt configuration
Hi, you may have more than one problem. There should be one belt from the mower deck going to the electric clutch pulley which is on the engine shaft. On the shaft there are two pulleys, one belt comes from the mower deck, and the other comes from the transaxle pulley. check to see if your belts are in the right areas.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 27, 2008
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
wadembly
  • 513 Answers
SOURCE: I am trying to replace my mower deck belt. I
got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
Posted on Jun 08, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
How do i replce the drive belt
This is not a very easy job to complete. If you have the owners pack that came with the mower, there are instructions with it, but you can also go to thier web site to down load the diagrams. the mower deck has to be removed to access the drive belt, so if you do this, remember or take digital photos of the removal so you can properly put tme mower deck back on.
Sep 13, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I am trying to replace my deck drive belt and do not remember how the belt goes around which pullies. Can you describe how to reinstall teh belt. My tractor is a standard lawn riding tractor by Poulan 18.5...
you may have missed it but the diagram is on the deck , look closely you should see it, anyway it should look like an upside down t if you were siting and looking at it from the drivers position. you should have to remove only one pin to get the belt on and it would be on the right side of the deck
Oct 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I need a diagram to remove a drive belt
You dont need any diagrams to change a belt just turn the mower up on 1 side and see where the belt goes and if you want to draw your own diagram and keep it safe But then you will find a idler drive pully on all mowers and that is either spring loaded or a nut and bolt holds it tight,,, and that could be the one that drives when you put the lever in CUT but have a good look and its easy to do..
Let me know how you go Ron
Oct 04, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Belt diagram for craftsman 46" model#917258691 I am replacing the secondary belt
belt routing diagrams are sometimes on the underside of the running board [so when you are laying on your back, you can look up and see it, left side usually]. on a 46 inch deck, it's probable that the diagram is on the rear, center of the deck, you can see it by going behind the tractor, kneeling down and looking forward at the deck
Jul 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
May 12, 2009 | Oregon Scientific Oregon Gator Mulcher...
Drive belt diagram
go to sears.com and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
Apr 30, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Drive belt popped off by limb i ran over need drive belt diagram
I've got a manual. Can I fax to you copy of diagram? Send your info to my fax no. 209-394-0868.
Mar 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
