Question about Sony BRAVIA KDL32BX330 32 Inch LCD HDTV - 31.5 Inch Diag
Green light flashes continuously like the up arrow on the remote is stuck (but it is not). Menu screen continuously scrolls up.
  • 34 Answers
SOURCE: Sony Bravia KDL-S40A12U Blank screen
Hello
on your set there is inverter board that is what lights up th backlight on your TV making everything visible that board has went bad.
Thankyou
Posted on Jul 28, 2008
  • 453 Answers
SOURCE: Sony Bravia 46S2010 LCD backlight ok , no video
yes it is
Posted on Jun 18, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Posted on Oct 01, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Posted on Oct 09, 2009
My sony bravia KDL-55HX800 SWITCHES OFF ITSELF
It appears to be a normal issue with this model, however there is an update on Sony's site that addresses that issue. If you look at the very bottom of the update details I'm about to post, you will see it
55 Class 54 6 diag BRAVIA HX800 LED Backlit LCD HDTV 3D
Click on Firmware and Read towards bottom of File Description.
The firmware update can be downloaded here
This is how to update by using a USB Storage Device
System Software Update 55 Class 54 6 diag BRAVIA HX800 LED Backlit LCD HDTV 3D
May 23, 2014 | Sony BRAVIA Televison & Video
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Model no. klv-22bx300 problem- green light
my sony KLV-22BX300 Tv when turn power on green led blinking,
and menu function not working properly
Jul 19, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
I have a sony bravia xbr 32 inch and the picture is only on half the screen
It is possible that Twin Picture function is enabled, turn it off with remote/ menu options.
If this is not the case then T-Con board sounds bad and needs to be tested/ replaced.
Qualified tv tech will test and replace it.
Thanks.
Oct 06, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Closed captioing will not turn off
Use the Menu button to get to the Settings menu to change the closed caption mode. Or use the Tools button on the remote to get to the Caption menu. See pages 31 and 39 in:
http://www.docs.sony.com/release/KDL46V2500.pdf
Sep 15, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL32BX330 32 Inch LCD HDTV - 31.5 Inch Diag Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
