Question about Hitachi VMH665LA Hi-8 Analog Camcorder
Hitachi VM-H665LA Hi-8 camcorder
The camera goes dead with fully charged battery. When I plug the recharger into the camera all is well but as soon as I remove the recharger cord it goes black again.
Buy new battery
Posted on Mar 06, 2008
SOURCE:
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
Hitachi (VM-E520A) camcorder battery problem
IT may be the charger itself try another battery to see if does the same or just simply the battery BURN!!
Jun 28, 2010 | Video Cameras
Fully charged battery in and it only lasts few minutes
you have to buy lithium battery's or lithium rechargable's. that camera should of came with lithium battery's did you get it used? and it should take usb.
Jan 02, 2010 | Sharp Viewcam VL-AH151U Camcorder
Dead batteries when fully charged
Does it work with "no batteries" - only plugged into power source? check your usb cable by trying to power up something else.
Jun 28, 2008 | Fuji FinePix S7000 Digital Camera
I was given a nice sony handycam camcorder. i was told the battery is probley dead
Batteries have a limited life even if they are constantly charged.
Leaving batteries in constant charge will limit their life by causing gas leakage. Once depleted, they must be replaced. There is also a small button battery that keeps unit memory up, if you do not use camera for months at a time, replace this battery also.
Ni-Cad batteries need to be refreshed ony once a month by discharging them fully, then recharging them fully for best performance to erase memory effect
May 01, 2008 | Sony Handycam CCD-TRV37 Camcorder
730 camcorder
well it sounds like the battery is dead. try charging it fully...if it doesn't work, then try getting a new battery for it, and if that doesn't work, try taking it in to a camera repair shop.
Apr 16, 2008 | Hitachi DZ-MV730A DVD Camcorder
Draining battery
This camera has had problems with the primary switch block faulting. The camera will power up all by itself when unattended and drain the battery. Another symptom would be the battery refuses to charge fully because the camera must remain in the "OFF" mode for the charge process to begin. Sony in Laredo, TX is replacing these controls at little or no cost, I would call them to see if they will repair this for you. Hope this helps you. Joe Weibel Custom Electronics (customelectronics.org)
Feb 11, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
New Batter won't fully charge and camera won't power off
The battery will not hold a charge or cannot be charged at all.
Follow the steps below to troubleshoot this issue.
IMPORTANT: It is recommended that you only use a Sony® brand rechargeable battery.
  1. Remove the battery from the camcorder or charger.
  2. Ensure the metal contacts on the battery are free of corrosion.
  3. NOTE: If necessary, the metal contacts can be cleaned using a soft cloth.
  4. Reinsert the battery into the camcorder or charger.
If the issue is still unresolved, then the battery may need to be replaced. If still unresolved after trying a replacement battery, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jan 04, 2007 | Sony Handycam CCD-TRV87 Camcorder
Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
Apr 13, 2006 | Samsung VP-W75 Camcorder
Hitachi VMH665LA Hi-8 Analog Camcorder Logo
282 people viewed this question
Top Hitachi Video Cameras Experts
Ekse
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
