Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Where to buy teledyne laas dr175 pressure flow switch
  • 372 Answers
The switch is widely available on-line if not locally available.
Posted on Nov 26, 2013
Jandy lxi 400p air flow fault
faulty air flow switch, blower isnt producing enough air pressure, or blockage in venting
Feb 06, 2012 | Teledyne Laars Laars Lx Pool Heater /...
LX400 low pressure switch
if good water flow through heater make sure if you have a bypass it is closed half way if not check pressure switch to see if 24 volts on both wires if not bad pressure switch or clogged copper line to it
Jan 02, 2012 | Teledyne Laars Laars Lx Pool Heater /...
I have older Teledyne Laars LPG spa heater and thermostat/heatcontroller has stopped working. Can I diagnose whether problem is electronic or physical? ie the very small copper tube from heat chamber to...
the pressure switch is connected to the copper tube check for blockage if ok check the wires to the pressure switch should have 24 volts ac on both sides if not bad pressure switch or connections make sure filters are clean
May 17, 2011 | Teledyne Laars END CAP - 10403800
I have a Teledyne Laars spa heater XE Electronic, ES 125 ; Question, The spa and heater was drained and cleaned about two years ago, I want to get running again, But before I fill the 500 gallon spa , Is...
Locate the pressure switch within the safety circuit and jump the two wires that are connected to it. Be sure the power is off when doing so. Then you can power up the unit and it should fire assuming all the remaining safety circuit switches are closed. DO NOT RUN this for more than a few moments as you can damage the heat exchanger rather quickly operating the burners without water flowing thru the heater.
John
Nov 09, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars pool heater llg175 turns on burner on for 10min then shuts off before heating fully, bay-pass valve checked ok . Pool heater pressure switched replaced.
Hello,Sounds like it is overheating due to restricted flow.If it is shuting down due to pressure.Maybe high limit?If it is oil fired try reducing the nozzle size/input.If gas you could reduce input pressure 1"WC.
Apr 20, 2010 | Heating & Cooling
It heats the pool but the hot tub gets warm for ten min then the heater shuts off ???
ARE THE TEMPETURE SET HIGH IF YES THEN THE FLOW VALVE IS BAD . WHAT ABOT THE FLOW TO THE SPA CHECK THE PRESSURE READING WHEN SWITCH FROM POOL TO SPA IF VERY HIGHT THE JETS MAY BE PLUG MAKING THE FLOW TO SLOW FOR THE HEATER TO WORK OK
Dec 01, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Piolet stays on,. burners do not go on heater will not start
could be many things ,start with pressure switch,check for continuity with multi-meter.if press switch isnt sensing water flow, your unit will not call for heat.let me know
Jul 04, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
How to adjust pressure switch
First off, you should not have to. Adjusting it can cause a dangerous condition if backed off to far and it allows the heater to fire without the pump on. That said, there should be a small 'toothed' disk just below the support arm. turning it adjusts the pressure required to close the switch. Whenever adjusted, make sure you turn the pump off and on several times to ensure the heater is reacting to the water flow.
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
MY Teledyne Laars is 20 year old +
check pressure switch (looks like space shuttle copper wire one side 2 wires other side) need 24 volts ac both sides if not need new
Dec 18, 2008 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
26 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
