Question about Toshiba E-studio 230 Multifunction Copier
Toshiba e studio 230 monitor (touch screen ) not display
When I on the machine switch that time touch screen light on but any text or any fuction not working
  • 24 Answers
SOURCE: Toshiba e-studio 35 Copier Problem
there is one more swith to off the machine.the switch which you are using is only for make the machine into energy saver mode.in that mode machine will be warmed up to take the printouts from computer.
Posted on Aug 31, 2007
  • 643 Answers
SOURCE: display F120 error in my Toshiba etudio 230
F120 indicates database abnormality.
What u can do:
1. Rebuild the database ( 08-684 )
2. If the error is not recovered, initialize the HDD. (Enter “2” at 08-690.)
PS: Press "0+8" & ON the machine in order to enter setting mode.
Posted on Jul 29, 2009
xptareq2000
  • 1447 Answers
SOURCE: Dear sir, when i start my Toshiba e.Studio 166
yes sir it is signal your copier exproser lamp or lamp fuse is cut please chack it then solve your problem
Posted on Aug 02, 2009
copiersplusw
  • 136 Answers
SOURCE: Toshiba e-studio 230 call for service
Call a Service tech
Have him reset yor Counter AFTER he over checks your copier and inspects the Drum,.Transer Unit, and Fuser Unit chances are the previous tech may not have reset the counter
but call for Service to verify those parts are good first ok. I would not want a counter reset to occur if a fuser unit is bad or something. At that low copies it maybe time for corona's to be replaced.
http://www.copierspluswwllc.com
Posted on Sep 13, 2009
  • 643 Answers
SOURCE: I have Toshiba e studio 207 copier machine. After
If not the contrast switch problem, u can try reset the machine by pressing "*13" and ON the machine.
Posted on Jan 01, 2010
What does call for service F 070, in toshiba e studio 230, refer to ? How can I solve the problem?
Toshiba Studio 230 Error Codes
Toshiba e-Studio 230 Error Codes Code: F070
Code
F070
Description
Communication error between System-CPU and Engine- CPU
Sep 30, 2016 | Toshiba E-studio 230 Multifunction Copier
My touch pad not working properly
Call Toshiba and talk to experts from the actual company. This should help. :)
Technical Support: 1-800-457-7777
Jan 11, 2008 | Computers & Internet
How to reset Toshiba e-Studio 161 Copier Copier with "error code H4"
Step 1:-
Press
"C" key AUTO/TEXT/PHOTO key
"C" key AUTO/TEXT/PHOTO Key
(Note:Perform the first two key strokes quickly )
Machine display should stop blinking
Now press 14 and press start button.
Switch off and on to check
Feb 27, 2016 | Toshiba Office Equipment & Supplies
How to fix id card fuction
first entered in SPECIALFETURES then
IMAGE COMBINATION then (Machine Ask Original Paper Size)
Select A5R (if the LTR Size Show tuch the AB botton)
Select 2 on one then select A4 paper tray
Then Screen Show Special features
DO NOT TOUCH RESET or Any botton
touch MODE MEMORY select M1 touch STORE then done then OK
Press the Additional Function Bottoan
touch Copy Setting
touch Standred key 1 setting
(in this Window show many botton)
choose modememory Select M1 Select OK
afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
Feb 25, 2015 | Canon ImageRunner 4570 | IR4570 |
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
What is the service code
There is no service code.
To reset the copier press and hold 0,8. button and switch on the copier.
enter 690 press start button
enter 2 and press enter key on touch screen.
once the reboot massage apears switch off the copier and switch on.
Mar 29, 2014 | Toshiba E-studio 230 Multifunction Copier
Richo infotec 3090 SC 593
- Toner Suction Motor Replace Alert.
- The total operation time of the motor exceeded 600 hours.
- The toner suction motor has reached the end of its service life.
- You can try rest it, after some time it will start to print light prints.
- So you will need to replace it.
- You can clear the code in Service Mode.
- To enter into Service Mode you need to follow the next procedure:
- Press the following key in the following order:
1. Press Clear Modes [yellow key] .
2. Press 1 - 0 - 7 [ with the blue keypad numbers ] .
3. Press and hold down Clear key [ C key] for 5 seconds.
(after release of the C key, the Touch Screen will change)
- On the touch screen press the [Cop SP] .
- Press the following number with the blue keypad:
[ 2 - 9 - 7 - 3 - 0 - 0 - 1 ] then press [ # ] .
- On the right side of the touch screen should write the following:
[ Toner Suction Motor Operation Time ] .
- Press [ 0 ] with the blue number keys, then press [ # ] .
- After doing all of this re cycle the machine by turning it off,
wait for 10 second, and then turn in on with the main power switch
[Red Power Switch] .
----------------------------------------------------------------------------------------*note: the machine will work again with this procedure but maybe,
after some time, or maybe even immediately after this,
the machine will start to make light prints.
Mar 12, 2014 | Ricoh Aficio MP 1600SPF Black Toner...
Toshiba 230 touch screen not working
You may need the latest driver... See here.... http://www.eid.toshiba.com.au/Downloads/manuals/230-280_350-450_3511-4511/eS230_350_3511_NetworkAdminGuide_Ver.00.pdf
Nov 26, 2013 | Toshiba e-Studio 350 Copier
Touch screen not working properly
Try to enter the following characters into the dialler: *#*#7378423#*#*
There you can test a fuctionality of the touch screen. If it's defective you have to change it. (In Sony service center they can do a touch calibration sometimes it helps)
Oct 14, 2013 | Sony Ericsson SONY XPERIA U ST25i...
Toshiba E-studio 230 Multifunction Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
