GE washer will not fill up. water continues to run
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Pressure sensor deftive
Posted on Nov 26, 2013
Oceti
  • 51 Answers
SOURCE: GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Posted on Jan 23, 2008
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
  • 117 Answers
SOURCE: GE Washer WHDRR418E1WW overflows the tube. Yikes.
A washer that over flows in the fill cycle sounds like a faulty pressure switch. Part # WH12X10069 and 10 on this diagram. If it overfills the tub when the washer is off it's a faulty water valve. Best of luck Ryan
Posted on Feb 25, 2009
  • 343 Answers
SOURCE: Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Posted on Apr 18, 2010
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Front Loader Washer continues to fill with water after cycle is complete
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Sep 10, 2011 | GE WSXH208A Front Load Washer
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
The water does not shut off even after it reaches the proper level it continues to run and it overfills and leaks out the bottom of the washer the clear hose is not clogged and we blow into it we can hear...
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 14, 2009 | GE WVSR1060A Top Load Washer
My washer keeps filling no matter the size I have
This sounds like a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water and signals the timer to start appropriate cycle. Make sure there is no damage to or obstructions in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | GE WSXH208A Front Load Washer
WILL NOT STOP FILLING
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling the washer then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. This should solve your problem. Happy to help, Tim.
Jun 30, 2009 | GE WHRE5260E Top Load Washer
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
GE Profile will not run cycles. Runs water continuously.
OK, i would do a hard reset by unplugging for 2 minutes. if the problem still exists, this is defiantly a malfunctioning relay. it will have to be replaced.
Mar 06, 2009 | GE Profile WPRE6100G Top Load Washer
Washer continues to fill after full, then spills all over floor until manual shut off
This is an indication of a pressure switch malfunction. Post back with your washer brand name and model number and I can tell you how to check it.
Feb 23, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
