Question about LG DLE5977 Electric Dryer
LG Dryer 5977 will not dry
When I turn the dryer on the check filter light flashes..not sure if this is normal,the filter is clean.However the dryer will tubble but will not heat or dry the clothes.I have reset the breakers (both) and disconnected the vent to ensure there is not obstructions.I tried drying in sensor and manual mode.Any ideas?
  • keoma Oct 11, 2007
    Thanks.There is a lot of air (cold) coming out of the vent,so I am assuming there is no obstructions and the blower is working ok.
    Can you let me know how to get to the thermal fuses?Where are they located?
  • cj762x51 Feb 20, 2008
    Have the same problem with the check filter light flashing and the dryer not heating up. found that the small thermal fuse is toast. got another one on order now, we'll see if that clears it up.
  • 94 Answers
If one of the two thermal fuses are blown you will not get heat.  Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot.  Often this is caused by not enough air flow through the machine.  Check and make sure your exhaust vent is not clogged.  Clean it the best you can to get all the lint, dead mice, bird nests, etc. out.  Also make sure air is blowing out of the machine when it is turned on.  If not you have a blower problem.
Posted on Oct 11, 2007
  • Prem Mulberry Oct 12, 2007
    Turn the power off to do this.  The thermal fuses are located on the element casing.  They each have two wires coming out of them.  They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across.
    The thermal fuses are located on the element casing.  They each have two wires coming out of them.  They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across.  With a multimeter, check the continuity across the terminals.  If there is no continuity the fuse needs to be replaced.
My lg Dle5977w cooling light stays on with the dryer light flashing when it's runing. Is that normal? Also it stops befour the clothing is dry having to run it a few times?
Check your vents. Make sure they are clean and not kinked.
When you open the door, is the air steamy? If so dryer vent is clogged.
Re the flashing lights, you may have to pull your customers owners manual for that answer.
Oct 18, 2013 | Dryers
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
Dryer model DLE5955W is not heating. When drying the "drying" light flashes and the "cooling" light is on steady. I turned off, turned breaker off and back on. No improvement. Checked lint filter, all...
You have one of 2 problems. There is a power problem at the power cord or the high limit switch has tripped. You will need a qualified LG technician to diagnose your situation.
Good luck
Oct 01, 2010 | LG DLE5955 Dryer
My LG DLE 5977 S Dryer doesn't dry the clothes completely. I have to restart it multiple times to get a load to completely dry.
Check to see if there is a kink in your vent hose in backj.
Go outside to verify
Clean filter with dishwashing liquid and brush
Run water on filter first to verify it doesn't go through
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
Sep 11, 2010 | LG DLE5977 Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Electric front load dryer flashes check filter.
what is the indicator lights in the board means. The green light is flashing one flash in then going into lock mode.
Model# RGPJ 05 EAUER
Jan 29, 2010 | LG Heating & Cooling
My lg tromm DLG3788W gas dryer is not heating, it says check filter. other wise it works fine. where is the filter at, i know the one where i open the door and clean the vent everytime i use it. thanks
I just cleaned those sensors at the bottom of the filter, it worked like a charm. The dryer is now drying perfectly, I did not know you were not supposed to use fabric sheets with this dryer. Now I know, Thank you for the good information.
Jul 30, 2009 | LG DLG5932W Gas Dryer
Dryer won't power up, says check filter
Check the door switch first.Than look for possible thermal fuse has cut off.
May 22, 2008 | LG DLE2514 Electric Dryer
LG Gas Stacking Dryer
The check filter light comes on every load to remind you to clean the lint filter. Cooling only happens when that light is flashing not when it's on solid. If this is a gas dryer check the exhaust hose and vent on the outside of the house. If it is blocked it will not let the unit get to the correct temp due to cycling.
Dec 16, 2007 | LG DLE2514 Electric Dryer
Check the vent and make sure it is not plugged with lint. Make sure the vent hose is clear. The light is telling you something blocking the airflow. You might not be able to see it easily.
Jun 18, 2007 | LG DLG2524 Gas Dryer
LG DLE5977 Electric Dryer Logo
316 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
