Question about Microwave Ovens
Take apart leland southwest 200da mixer - Microwave Ovens
How many amps a fuse in breville mixer
Not knowing the model of the mixer you are talking about, or where you are in the world and the voltage you are running at, I can't tell you. But I can tell you how to figure it out. Simply do this:
You obviously know what your main power supply voltage is, either 240 volt or 110 volt
You can look at the mixer and there will be a data sticker with the wattage of the motor on it
Watts divided by volts = Amps
Therefore, if you have a 500 watt mixer on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
a 750 watt motor on 240 volts 750/240 = 3.12 so use a 5 amp fuse
a 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
etc etc etc.....
Hope this helps
Jul 26, 2011 | Microwave Ovens
Hi, I have a kitchenaid mixer from the US and want to get the voltage changed to work in Australia. Can you advise on where/how I can get this done please?
As your mixer runs on 110Volts. When you get to Australia, find an electronics/hardware store and there will be access to 240 ~ 110 transformers. The only critical bit is the current the mixer draws. Add 10% to be on the safe side. Or another option is to replace the motor with a 240Volt version when you are there unless one is available now at a good price.
Hope that helps.
Mar 08, 2011 | KitchenAid Microwave Ovens
I have a black and decker hand mixer model no BSM 101, but the mixer is not working. When i put the switch on the below portion which is supposed to turn does not urn only the motor is becoming...
From your description the motor has become seized and the only option is replace the motor, but probably not cost effective, serious consideration should be given in just replacing the entire mixer.
Mar 05, 2011 | Microwave Ovens
The "pin" (I think it's
well its not in a microwave is it? its in your mixer,,,,yes they do get stuck in and also out,,,its down to lack of servcing,,,try giving it a splash of WD40 and a good working over with some thing to "flick it with!" it may start moving again,,,,,wash it well after and next time dry it off better before you put it away?
Nov 28, 2010 | Microwave Ovens
Looking for C100 mixer manual Hobart
Toll free: 877-828-4616. Complete manual available. ... C10; C100; A120; A200; D300. These mixers can be damaged, broken, with burned up motors, etc. ...
www.food-equipment.com/parts_Hobart_mixers.htm
Nov 01, 2010 | Microwave Ovens
ON CHRISTMAS AS I MIXED A CAKE MY KITCHENAID MIXER SOUNDED LIKE IT WAS STRUGGLING, THEN IT JUST STOPPED RUNNING. MY MIXER IS LESS THAN 5 YEARS OLD AND REALLY HASN'T BEEN USED VERY MUCH. PLEASE TELL ME WHAT...
Is the warranty still valid?
Is there a recall on the model you have?
Typically the problem you describe is a problem with the motor brushes or you were mixing more material than the mixer was designed to mix and the internal thermal link failed.
The mixer is too young to develop this problem without abuse of a material flaw.
If there is no recall on it and the warranty has expired your best bet is to buy a new mixer. Repair cost will typically exceed the cost of a new on if it was a cheap model costing less than $50.00.
Jan 06, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
