Question about Swingline 87850 Optima PowerEase ? Full Strip Stapler
How to fix a rapid 20EX electric stapler - Swingline 87850 Optima PowerEase ? Full Strip Stapler
When on the stapling process even when it's pushed down the staple wire is not cut.
Probably too late but, here is what you need to repair this expensive stappler instead of buying a new one:
https://www.stapleheadquarters.com/ItemForm.aspx?Item=DUAX29
May 16, 2016 | Rapid DUAX Heavy Duty Stapler 2-170 Sheet...
Where can I get a couple Panasonic AS-500 Commercial Staplers repaired? Have tried calling Panasonic at 1-800-405-0652 option 4 but got nowhere.
This is a rather rare request, as very few places fix staplers.
I should recommend you find a "handy-man", maybe an older person with a hobby, and he may be able to help you.
I fix staplers, but have only been successful about 50% of the time.
God bless your efforts.
Feb 25, 2016 | Panasonic AS-500 Commercial High-Capacity...
How do I prevent Rapid 5080e stapler from jamming
Make sure that the tray for the staples is clean and LIGHTLY oiled, Staples are held together with glue. IT could also be an issue with the wear on the staple head driver. If you use it a lot, the unit might be worn to the point that it is out of spec.
Aug 28, 2015 | Rapid 5080E HEAVY-DUTY FLAT CLINCH...
HOW DO YOU OPEN AN ELECTRIC STAPLER
normally the metal tray will just be able to slide out, or the top will be able to pop off.
Aug 22, 2014 | Office Depot Brand Half-Strip Compact...
Bostitch electric stapler wont open
Hello, Go to this website for support number and downloading of the operators manual for the model of stapler. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
May 01, 2014 | Stanley Bostitch B8 Electric Stapler
Loading pencil
Have you tried a metal nail file, thin tipped knife or a paper clip?
Jan 14, 2014 | Leitz Rapid 02892 Heavy Duty Cartridge...
How to fix bostitch electric stapler
Hi, I am having trouble reloading staples into the stapler, i press the button on top, and in the front, and nothing happens. the light won't turn on when i plug in and unplug and plug back in
Nov 13, 2012 | Stanley Bostitch 02210 Electric Stapler...
Swingline 87850 Optima PowerEase ? Full Strip Stapler Logo
264 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
