REMOVE CD WRITE PROTECT WIN 8 - Computers & Internet
  • 27,725 Answers
Open windows explorer
Right click the icon of yourcd/dvd drive (It should be D:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Then advanced sharing place a tick in share this folder
Posted on Dec 06, 2013
Won't work on windows 10
with a new operating system (win10) you will have to install the driver for the plug in unit
May 04, 2016 | Praktica MicroPix Digital Camera
Old CD how do I open it in Windows 8? It is c 1994. Need to use it.
it may not work in win 8 but give it a rty
put it in the cd machine and it should auto read and the win installer wizard should take it from there
if it works then click on the program and click on properties and select compatibility -change to win 8
basically there are procedures to follow ( like system manager or open cd in computer manager ) so it may be easier to get some it person to come and help with the installation unless it is a laptop in which case take it all to a shop and have it done
Jul 21, 2015 | Cosmi PC Attorney (Win) for Windows
How to uninstall window 8.1 and reinstall window 7?
Becouse you have installer the O.S. Windows 8 , go to right egde down or up > click on Setting > next > update and recovery > click on the second option { recovery } ,choose the option number two [ REMOVE EVERYTHING AND RE-INSTALLER WINDOWS } and now you can insert windows 7 disc, good luck.
Jul 31, 2014 | Medion Computers & Internet
Had win8 went back to win7
Drivers can be found here:
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-15-3521
You probably need the Network & Chipset drivers, but make sure you get the right ones for your model.
Nov 05, 2013 | Microsoft Windows 7 Home Premium for PC
The CD -rom not compatible with windows 8. it works on windows 95
Between Win95 and Windows 8 there are several other versions Win 98, Win 2000, Win XP, Vista, and Windows 7. Try to run the CD in compatibility mode. If it does not work you will have to forgo the use of that software or run it on an old machine, or upgrade to a version compatible with Windows 8 if one such upgrade exists.
Aug 31, 2013 | Expert Software Computers & Internet
Tried to update win 7 to win 8 but when loaded receive message OXOOOOOO5D nowcan,t start computer
windows 8 is far better than windows 7
To install Windows 8 on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system. To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled"), feature within the BIOS settings. This feature is typically found in the Advanced or Security tabs within the BIOS settings, and can be referred to by a variety of names, including but not limited to: • No Execute Memory Protect • Execute Disabled Memory Protection • EDB (Execute Disabled Bit) • EVP (Enhanced Virus Protection) If the BIOS setting for the NX (XD, EDB, or EVP) support option is not available on your system, you may need to contact the manufacturer to update the BIOS. Note that some very old processors may not contain these features and will be incompatible with Windows 8 Release Candidate. A whitepaper has been published with further details about the PAE/NX/SSE2 requirement for Windows 8, error cases and scenarios that customers encounter when machines fail to meet the requirement, and what to do to install Windows 8 on their PC's. You can download the whitepaper at http://msdn.microsoft.com/en-us/library/windows/hardware/hh975398.aspx
Jan 18, 2013 | Computers & Internet
How to get Drivers Updates after Windows 8 Upgrade for Toshiba C660D Laptop Please
This is a common problem with a new OS upgrade. Try to use Win 7 drivers. Modtify the drivers to be compatible with Win 8. Most times this will work, not always. Try here for Win 7 32 or 64 bit drivers: http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK&mode=allMachines&action=search&teddProduct=6017&selShortMod=1041
Dec 03, 2012 | Toshiba Computers & Internet
New drive for win xp?
No drivers required but use a burner called NERO 8,its great.
Feb 25, 2010 | QPS Que! Combo Drive CD-RW/DVD-ROM Burner
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Cant instal win xp on dell xps 700 help pls
1.) Insert Bootable CD.
2.) if not booting up, go into the Bios and change the bootable device list to list the CD or DVD drive first
3.) Disk should boot, if not then you have a problem with your CD (try another) or the CD/DVD Drive is not working properly.
Nov 09, 2009 | Dell XPS 700 PC Desktop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
