Question about Stoves Ovens
Burners and oven do not come on
Can't hear striker
When i turn on the knobs to the burners i dont hear the hissing sound and the burners do not light or anything..
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Ovens
Oven door won't stay closed
You don't state the exact model but on every oven I've ever fixed this problem on it's a broken door striker catch. Depending on your model, the catch will either be in the oven door or in the oven body; usually they're straightforward to replace but on older ovens spares can be almost as rare as dodo ****. Usually what breaks is a hardened tempered metal spring, so when they're not available as spares I can usually visit a local spring making company and get someone to make one up as a one-off using the fragments of the old one as a pattern. After the catch has been replaced the striker itself (usually a specially shaped pin) may need to be adjusted to engage correctly once more. Undoing the lock nut and screwing it in and out adjusts the depth, and is done after the striker catch has been adjusted side to side or up and down to meet the centre of the striker.
Mar 04, 2010 | Imperial Ovens
Whirlpool 465. The top range burners will not ignite. I can hear and smell the gas. The oven burner works fine. Do I need to replace an ignitor for the range?
The bake is seperate from the burner ignition system. You may need a new spark module for the top burners. All burners should spark at the same time even if you are only trying to lite one burner.
Aug 27, 2009 | Ovens
Gas stove the burners are working but the oven is
Hi, The ignitor in the oven does not spark. It glows and has to pull enough amps to open the safety gas valve. The most common issue with these ovens is the ignitor. It can glow red but not be strong enough to open the valve. Remove the bottom panel in the oven and you can see the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Ovens
Mid 90's Magic Chef gas stove
hi there,
since you can smell gas, you have a gas leak. i would recomend checking and cleaning the gas valves. if you can hear sparking, that means it's just the valves. sometimes cleaning the rods will fix the problem.
Oct 10, 2008 | GE JGRP17 Gas Single Oven
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
IMPERIAL ICV-1 SINGLE DECK CONVENCTION OVEN
this is a common indication that the ignition module is probably going bad or the flame sensor is not sensing the flame on the burners. There are other, more technical issues possible but this is usually the most common. The "not restart" , if referring to the burners, is an indication that the ignition module has "locked out" the system, usually after 3 failures of attempts to light the burners.
Oct 31, 2017 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
13 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
