Question about Car Audio & Video
Aerial won't go up
Why won't my pioneer electric car aerial return
  • 26 Answers
If this is an electric antenna it has a motor that makes it go up and down. Either the wire from the car stero is not hooked up to send to the signal to the motor or the motor itself needs to be replaced.
Posted on Jun 07, 2009
Hi I have a pioneer avh.x3500 that displays ANTENNA ERROR all the time! Is there a fix for this? JJ
Check the connections for the aerial to the device. If they are good and the aerial gives out a good signal then there's an electrical fault on the unit.
Apr 07, 2017 | Pioneer Car Audio & Video
Renault Megane cabriolet 2002 1.6 16v Electric Aerial out and doesn't get back in. Where are fuse and relay ? Thanks.
electric aerial megane cabriolet 2002 - Renault Forums ...
www.renaultforums.co.uk > ... > Ask the Experts > Electronics
Dec 8, 2013 - 3 posts - ‎2 authors electric aerial megane cabriolet 2002 Electronics. ... 2002 Megane 1.6-16v cabriolet, well on drive as no garage lol. tynesidelad is ... Take it out and check it ,hopefully enough room to remove it from below,(is it motorised?). Megane mk1 cabriolet
Apr 3, 2013
Megane Cabriolet Aerial stuck
1 post
Jun 22, 2011
More results from www.renaultforums.co.uk
Jun 22, 2011 | Renault Sport Cars & Trucks
TV OK when displaying Sky, but on terrestrial the picture occasionally breaks up with audio crack. Aerial signal is good, with a new aerial and aerial amplifier. Problem is gradually becoming more...
Sounds like a simple cable issue, have you tried switching out the audio source cable? Or are you running HDMI? if so I would switch out the HDMI cable also.. Hope this helps..
May 28, 2011 | Pioneer PDP-4350HD 43 in. Plasma...
On a Panasonic radio/cassette player model-CQ-RD910 Len,which colour wire is the trigger/sender wire for an electric aerial/antenna to extend or retract the mast. The electric aerial/antenna drive motor...
The " Blue & red spotted " wire that is spare from the rear of the radio transpires to come from the " cold " side of the radio's on / off switch , and serves to be only energized when the radio is switched-on and slowly shuts down on supply voltage when the radio is switched off , thus giveing a supply voltage for the relay & switch over reed switches in the aerial / antenna motor unit for a short run-down-time , to change over and allow the aerial mast to retract , in readyness for when the radio is switched on again and the aerial/antenna mast will power up .
This trigger / sender wire is connected via a 2 amp. fuse through to the aerial / antenna power relay.
The main aerial power motor unit is fed via a 6 amp. fuse.
Dec 12, 2009 | Panasonic Car Audio & Video
Electric car aerial
Open the bonnet (hood) and prop open with a golf umbrella, remove three bolts holding the wing onto the engine compartment and one bolt in the middle of the door frame (with the door open), you can then pull the wing off enough to be able to remove / change the aerial.
The fixing at the bottom of the aerial unit to a bracket on the wing can be difficult to undo; I just broke it off and fitted the new aerial without the bottom bracket fixing.
Aug 16, 2008 | Hyundai Motor 1998 Accent
Electrics
Might sound silly, but physically remove each fuse in the engine bay, check the fuse receptical for corrosion, dirt, etc. Check each fuse with an ohm meter for continuity and return to socket. Had one socket acting up on mine.
Aug 06, 2008 | 2003 Kia Sedona
Only have 1 remote wire for aerial
hello simple ..just put a on/off switch inline with you aerial power lead ..amps will stay on ..if you dont want the aerial up .just flickm the switch off..down it goes
Jan 30, 2008 | Car Audio & Video
Car Audio & Video Logo
225 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
