Question about Rockford Fosgate Punch P3002 Car Audio Amplifier
Rockford Fosgate P3002 stopped working
So I was driving around the other day with the tunes goin, everything was fine until my subs all the sudden stopped working. All of my connections are good because the amp will still turn on and light up. The rf symbol no longer jumps to the beat either, I've changed my rcas and that didn't work. Neither the power or the thermal light comes on when I power the amp. Is the amp bad or is the deck not sending a signal? All help is greatly appreciated!
  • 47 Answers
Push down and up on your subs and see if they make a starching noise, if they do then they are blown. take a test light to the amp, on the power and the remote and see if it lights up. if it does then turn the amp down and with a small speaker plug it in to the speaker outs on the amp and see if it plays if not then your amp is bad.
Posted on Dec 02, 2013
  • 109 Answers
SOURCE: My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Posted on Jun 24, 2008
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
  • 102 Answers
SOURCE: amp only has red thermal light on. some times the
Please review your wiring, both INPUT and OUTPUT
Posted on Apr 12, 2009
etirbynnor
  • 655 Answers
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Posted on Apr 28, 2009
laseramp
  • 309 Answers
SOURCE: 401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
the problem is mostly with your audio side of the amp. i have a 800 Rockford punch series amp hooked in series running at about 15 vdc at 2 ohms stable for now. but the amps left front power side transistors overloaded and smoked out, i will be replaceing my mosfets soon. Now on that side your issues apear to be related to the signal side of the amp. when you hooked the amp up tell me breifly did you hook the rca inputs to the back of the sterio and did you select the proper rca inputs for the amp? also note that amps have a potentiomater that can be tuned up or down to allow the volume or wattage to go up or down threw the system. if it's turned all the way down you'll here nothing. but often you'll get a pop sound or quickly see the speaker move a bit. this indicated the signal side of the amp has signal comming in but no output, just look for a turnable small screw inside the amp top or side. and turn up acordingly. note: to much output will damadge your system. not just the amp. ;)
Posted on Aug 28, 2009
I have a 12 inch rockford fosgate subwoofer. It just completely stopped working. cosmetically, there is nothing wrong with it to the ***** eye. My amp works just fine, but the sub doesn't do...
First, switch channels to make sure it's the sub. Check to make sure the tensil leads that go from the + and - posts to the voice coil have not come loose. If that's not the case, the voice coil may have failed.
Aug 31, 2011 | Rockford Fosgate Car Audio & Video
Can you replace the cooper coil inside a subwoofer sony xplod 12 inch
No sony doesn't not make repairable subs. I suggest avoiding sony xplod everything, they are nothing but problems. For subs try to go for Cerwin vega, rockford fosgate, clarion. The rockford fosgate is the best and when giving the power will tear apart your car and having you jamming all day long
Mar 22, 2010 | Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
Protection light goes on and off
test subs you may have blown the voice coil
Jan 18, 2009 | Rockford Fosgate Punch P4004 Car Audio...
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Amplifier cuts off
your ohms on your subs are not wired right good luck
May 25, 2008 | Rockford Fosgate Punch P3002 Car Audio...
Rockford Fosgate P3002 Amp
what are the color of the lights that stay on.red= protect/ green=on.if the amp has little sound it probably still working,check deck output volume(rca)
Aug 22, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Rockford Fosgate Punch P3002 Car Audio Amplifier Logo
125 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
