Question about AST Vehicle Parts & Accessories
Ultra remote starter starts my 2007 dodge ram ram runs a few seconds and shuts off horn blows and light flash then starts and stops again
    Prodigy:
    An expert who has answered 500 questions.
  • 652 Answers
Sounds like the factory securty system shutting it down
Posted on Nov 26, 2013
4 Suggested Answers
  • 12 Answers
SOURCE: remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
Posted on Jan 15, 2009
  • 26 Answers
SOURCE: viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Posted on Jan 16, 2009
  • 11 Answers
SOURCE: how to bypass security system for remote starter
the easyest way to to this is useing DEI Part# 556U you will nned extra key but i think its easyest.or XKO3 if you dont have extra key.
Posted on Nov 10, 2009
2000 stratus beeps twice, flashes twice, repeats untill stopped, but it drives
This is usually a good situation to bring to alarm shop and have them take it out and see if you can just keep the remote start or it might need a new brain on the alarm system
Dec 10, 2013 | 2002 Dodge Ram 3500 Truck
ENGINE WILL NOT TURN OVER/SPEEDO AND TACH LIGHTS FLASH
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Diagnostic Codes 04 to Present
Jun 04, 2012 | 2007 Harley Davidson FLHTCU Ultra Classic...
Secureilock error code 13 on 2007 ford expedition. I am having problems remote starting my expedition.
Securilock problem for your remote start? Check when you try to start it, if the security light is flashing fast it is probably the PATS (security system) bypass. To reprogram it you will need two keys. First insert the first one and turn it to the run position. When the security light shuts off insert the second key and turn it to run. Once the light has gone off the second time pull the key out and hit the start button on the remote start fob, this all has to be done in 10 seconds. The vehicle will start, shut it off and try it again. If it doesn't start look to see if the security light is flashing fast again if it is the bypass needs to be replaced. If the light isn't flashing fast and it still doesn't start it should be honking at you or flashing its lights, count these then look in your manual it will tell you what is wrong. If none of these work let me know and I will help you. You can also check out my profile I have a tip that is about remote starts.
Good Luck
Dec 26, 2010 | 2007 Ford Expedition EL XLT
Python ce0890 FCC ID EZSDET474P RPN 473P 266 CODES. How do i reset this devise? The battery is good
While our Dodge ram truck sits - the horn starts blowing. We think it has to do with the remote and the security. We have the Python CE0890 remote starter - it is a few years old.
Dec 06, 2010 | 426P 460HP Security System - 426P
With ac running cold, blows warm when truck is stopped
I have a dodge 2007 ram 1500...most likely its an RPM issue. The compressor requires a certain RPM to maintain the required pressurized vapor.
Apr 29, 2009 | Heating & Cooling
1999 F350 horn blows all on its own...
I think your horn relay is making contact from behind your horn buttons on your steering wheel. Usually as time creeps up the insulation that is placed on the positive lead for the horn gets worn out from constant horn action. If it is worn down the horn is touching a ground and completing the circuit and thus making the horn sound. I would start with that first before getting more technical. Let me know. Gabe
Apr 20, 2009 | 2000 Ford F350 Super Duty Super Cab
Alarm
Mine has done this and i as well do not have a working remote. To disengage it just put the key in the driver door lock and turn for 2-3 seconds and it will disengage. i didn't even know mine had an alarm until coming out of work one night and it went off and i could not get it to turn off unless i went to "unlock" the door and hold it there for a few seconds.
Apr 14, 2009 | 1999 Dodge Durango
Wife washed key remote for my 1999 mercury grand marquis.So I tried the remote and it activated the alarm just fine. About 30 seconds later the lights start flashing and the horn starts blowing and will...
I took the battery out of the remote,therefore not allowing the remote to send bad security codes to the system.The backup remote operates the system perfectly.I am allowing the main remote to dry several days and will try it again.If not,I'll have to buy a remote if I want a backup remote.
Apr 09, 2009 | Mercury Vehicle Parts & Accessories
Dodge ram van e250 dies while driving
try changing the coil- sometimes they get hot and break down- once they cool off vehicle will start and run until they get hot again
Jul 05, 2008 | 1992 Dodge Ram 250
Horn
my horn did the same thing - we disconnected the horn (which in an 02' is behind the passenger side headlight) I'm sure it's wearing out and we need to replace it.
Jun 29, 2008 | 2004 Dodge Neon
Vehicle Parts & Accessories Logo
144 people viewed this question
Top AST Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an AST Vehicle Part and Accessory Expert? Answer questions, earn points and help others
