Question about Garden
Uberhaus 4 element infrared heater
Need manual
I have a Uberhaus patio heater and I need replacement parts
sadly I can not find any listing for Uberhaus heaters or parts for it
May 23, 2018 | Heating & Cooling
Need manual for wall mounted heater ,uberhaus bc15-15e2p
Try Googling (uberhaus)(bc15-15e2p)(manual) without parens.
Jan 16, 2018 | Heating & Cooling
Hi we have a uberhaus dehumidifier model no.MDK-40AEN1-BA9.. Forgot how it works ..how can i get a manual thanks
Try Googling (uberhaus)(MDK-40AEN1-BA9)(manual) without parens OR request the manual directly from Uberhaus.
Nov 12, 2016 | Dehumidifiers
I recently purchased an Uberhaus Air conditioner Model GJG148M-A3RND21. I need manual
Ty Googling (Uberhaus)(GJG148M-A3RND21)(manual) without parens.
Oct 09, 2016 | Heating & Cooling
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
" 1500-w wall convector" from uberhaus compared to "1500-w electronic converter" Stelpro
One of the main differences is the stelpro is 110 volts and the uberhaus is 240.
Dec 02, 2013 | Fahrenheat Electric Convector Baseboard...
Bulbs burnt out
i would check with the manual to see if it can be replaced it look like heating elements not bulbs
Mar 16, 2013 | Pool & Spa
How do you change the heating elements
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95.
You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
There are links to the instruction manuals there as well. They include information of how to replace the elements.
Nov 22, 2009 | Marvin W.B. 7260 Quartz Heat N Light...
I need the replactment elements for a Marvin 2060 heater, where can I find them?"
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95. You can order them directly here:
Nov 16, 2009 | Marvin 2060 Compact Heater
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
