Question about Broan-NuTone QT100L Fan
Glass replacement I broke the glass light cover on my LS100L exhaust fan how do I replace it ?
Where can I find SMC Ceiling fan replacement glass light cover? I broke mine.
Most likely you'll have to contact the manufacture
Jan 31, 2015 | Dryers
Where to find ceilng fan replacement parts?
you can either check the company that made the fan or try your local home depot in the light isle towards the back you should see fan parts and light globes.
Jun 07, 2010 | Hampton Bay 04345 Cruiser Ceiling Fan
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
Light cover/Dish for ceiling fan
My installation instructions say call 1-800-295-4448 and give the following infromation: 1. Part number 2.Part description 3. Style number of your fan. It is part number 31 Glass Shade
Jul 11, 2008 | Dryers
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Broken glass light cover...
you should be able to use the unit without a problem,in between the panels where the light is theres insulation.you can try northernparts.com they may have a replacement cover for your unit.
Dec 25, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Glass Surface Light Lens Cracks from Halogen lights use
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 06, 2007 | GE XL1800 1100 Watts Microwave Oven
Broan-NuTone QT100L Fan Logo
207 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
