Question about Linksys StackPro II 100BaseFX Distance Extender (DSHFXSC)
I recently upgraded my computer from Vista to XP Pro, and in the
process of formatting the C: drive, lost a lot of information about
hardware. I now have a wireless adapter which works, but I can't
get a LAN connection to. Any advise?
The driver file formats are not excuteable thats why you cannot open files to install lan drivers. its so funny the way broadcom done it.
Posted on Jun 11, 2008
Just go here... (= http://support.acer-euro.com/drivers/notebook/as_3690.html
Posted on Jul 05, 2009
You can get this driver, and any others, form the Acer site:
http://us.acer.com/
Follow the "notebooks" link.
Posted on Oct 11, 2007
You did say you drivers are bust and cant connect to the internet..
Ok no big deal...
1.March yourself down to your local electronics store buy a 1gb thumb drive.
2. Go to your local library stick in thumb drive and down load the drivers.
3. go to your machine and install drivers from thumb drive
4. Configure your machine
5 enjoy
Posted on Jan 27, 2008
U have install broadcom GigaLan Drives in your system. after u have start the setting of wireless LAN.
By. Network Operator (Mahesh Chauhan)
Posted on Sep 15, 2009
** Still Same Not Able To Enabale Wifi In Aspire 3690 ** I have my Acer Aspire 3690 i reinstalled the WinXp
i installed the wifi card it seems to work but it doesn`t. I go to
enable wifi it says enabled, however it stays disable and i cant use
it. I bought another wifi card that one doing the same !! Is There Any
Solution I Couldn`t Found Any !
The original one is Broadcom BCM94211MCG
The second one what i just bought is a Gigabyte GN-WS50G Atheros AR5007 chipset minicard mP
Thnx .. two total differnt both of them doing a same thing , one more
thing originally its came with Windows Vista (it sucks on a weak
computer like that even if i extended the ram) so now its running with
WinXP .
Posted on Jul 11, 2008
I emailed acer--was told to get drivers from maker of device.
Posted on Oct 25, 2007
You will need to reinstall the LAN driver. Go to Start >Control Panel > System >Hardware >Device Manager and select the LAN network card to reinstall the driver with. If you don't have the disk, then use the wireless connection to access the internet and search for the driver to download.
I found the network drivers on acer europe site.
Posted on Jun 28, 2010
Assuming that the LAN cable connection and Broadcom drivers were all valid and working. Then perhaps the wrong firewall setting may have caused the connection to fail.
I experienced the same problem where the wireless worked fine while the LAN did not. Through trial and error in searching and changing various network settings, I came across the Computer Associate firewall software package had the Broadcom 440x bit assigned to 'Restricted', comparing to the 802.11g where its at 'Safe'. Thus blocking the LAN while allowing the wireless access to the internet. This may also be applicable to other firewall software packages.
If you have the same CA firewall, then just step through the following to see if that would do the trick:
Access CA Personal Firewall => Firewall (button on the left) => Zones tab => Zone Assignment
Then find the 440x and right click to change its assignment from 'Restricted' to 'Safe' to restore LAN access.
If you have the same CA firewall, then just step through the following to see if that will fix the trouble:
Posted on Feb 09, 2010
Dec 27, 2012 | Computers & Internet
Nov 11, 2017 | Acer Aspire 3690 Notebook
May 16, 2010 | Acer Aspire 3690-2196 Notebook
May 02, 2009 | Computers & Internet
Mar 27, 2009 | Acer Aspire 3690-2196 Notebook
Feb 14, 2009 | Acer Aspire 3690-2196 Notebook
Jan 08, 2009 | Acer Aspire 3690-2196 Notebook
Jul 31, 2008 | Acer Aspire 3690-2196 Notebook
Apr 07, 2008 | Linksys StackPro II 100BaseFX Distance...
Mar 15, 2008 | Computers & Internet
6,010 people viewed this question
i recently updated my pc and now it reads internet connected but there is no network it is connected to
I have an acer aspire 3690. it connetcs to tthe internet via the wireless network but i have NO drivers for the network card. I cant seem to find any anywhere
I ended up (with my wireless connection - no need to go to the library for me) downloading the broadcom suite. It worked for both my wireless and LAN adapters, and while it has some incompatibilities (If I want to "search for wireless networks in range" using windows, I have to enable that every time) but other than that it's fine. There are still a lot of unfinished things but it works for the most part.
Lee
i want lan driver to acer aspire 3690 quicly
