Question about Frigidaire Built-In Microwave
Has power but won't heat - Frigidaire Built-In Microwave
  • 2,113 Answers
Replace your magnetron While the cabinet is open check the thermal cutoffs and look for melted wires Tap the relay in case it sticks Check the circuit board for burnt traces or components etc
Posted on Nov 26, 2013
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Kenmore 721.80403 microwave won't heat
If the turntable does move as well it is likely the inverter (power) or the Magnetron itself.
Nov 03, 2012 | Kenmore Microwave Ovens
Jenn air microwave makes zapping sound and won't heat food
Possible bad inverter board (power) and or the Magnetron which does the main heating.
Oct 31, 2012 | Jenn-Air Microwave Ovens
Everthing works but won't heat
If turntable works suspect inverter (power) or Magnetron itself is bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My Oster OM1201eovg microwave will turn on but it won't heat what I put in there. What's the problem?
Either the inverter which powers things or the Magnatron which in effect does the heating are bad.
If a fairly expensive unit it may be worth repair as these are of course two of the more expensive parts in the unit.
Sep 04, 2012 | Microwave Ovens
you have a power diode defective, high capacitor or Magnetron, test it for open with DVOM OR VOM , or better consult the qualified tech, Because this involve high voltage.
God bless you
Jul 10, 2012 | Frigidaire GLMV168K Microwave Oven
MICROWAVE WON'T HEAT
HELLO.
If you are sure that your microwave is powered on but not heating.then you are having element fault with your microwave.this is the solution below,
Things you will need
  • Oven Heating Elements
  • Screwdriver Sets
    1 Turn off the power to the microwave at the breaker box.
2 Take out the screws holding the element bracket in place. These will be on the back wall of the microwave, or sometimes on the top.
3 Pull the element toward you a little bit until you see the wires behind it.
4 Unscrew the leads and take the bad element out.
5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
7 Fasten the brackets, making sure they're tight.
8 Restore power to the appliance.
Thanks.
Sep 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat up. We have power
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 24, 2011 | Frigidaire Microwave Ovens
Frigidaire Built-In Microwave Logo
29 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
