Question about Texas Instruments TI-83 Plus Calculator
Residual missing from my calculator
I can't find residual in lists. It was there before but now gone
The residual list on my ti-84 calculator is not showing up after I reset the memory, what do I do?
When you reset the Memory you clear all in the RAM. Recreate your tables. If you do not want to lose something you created, archive it.
Mar 09, 2015 | Texas Instruments TI-84 Plus Silver...
How do you make a residual plot? And I don't mean finding the residual line and plotting it in a regular scatter plot. I'm talking about a residual plot with a horizontal regression line at zero and the...
The simplest way would be to create a table where each x-value has a y-value that is the residual at the corresponding x. With a 2-list data set you can plot you residual plot.
Sep 22, 2013 | Texas Instruments TI-86 Calculator
My TI 84's diagnostic on button isn't working!!
I believe that there are a few things mixed up here. The DiagnosticsOn command turns the diagnostics on to allow the calculation of the correlation and the determination coefficients for the Regression models for which they are defined (meaningfull).
Regardless of the Diagnostics ON or OFF option, the residuals are calculated automatically and stored in the RESID list. You can have the graph of the residuals displayed. By examining it you might decide to select a different regression model.
See Chapter 12 of the manual, which you can find at this address.
Feb 29, 2012 | Texas Instruments TI-84 Plus Silver...
In my Nokia7210 supernova the calculator is missing i restore the phone bt calculator is still missing
sir mere nokia 7210 supernova phone se calculator gone ho gaya hai iska solution bataye''''
maine resetall or restore bhikar kar dekh liya magar nahi aya
Dec 21, 2010 | Nokia 7210
The residual function as well as the r squared function are gone! They aren't even in the catalog and when I reset it they don't come back! What can I do to get them back?
Press MODE to get into the mode editor. Press up-arrow as needed to get to the "STAT DIAGNOSTICS" line. Use right-arrow to highlight ON. Press ENTER to save the change, then 2ND [QUIT] to exit the mode editor.
Nov 29, 2010 | Texas Instruments TI-83 Plus Calculator
Residuals!
Enter your data in List1 and List2. While data is in display
  1. recall the setup screen by pressing [SHIFT][MENU] (SETUP)
  2. Use down Arrow to scroll down the list of setup options to highlight "Residual List"
  3. Press [F2] (LIST)
  4. Press [F3] to select List3 as the destination list for the residuals.
  5. After you perform your regression calculations, the residuals will be in List3.
Jan 12, 2010 | Casio FX-9750GPlus Calculator
I am trying to graph a residual plot as L3, but the graph isn't working. It's not even working for L1 and L2. Do I have a wrong setting?
I think you should run the SetUpEditor. Press [STAT][5:SetU[Editor][ENTER] to configure the calculator to perform a new statistics problem.
If you still have problems, clear the lists of all data and restart. Press [2nd][MEM][4:ClearAllLists][ENTER].
Hope it helps.
Thank you for using Fixya.
Nov 24, 2009 | Texas Instruments TI-83 Plus Calculator
Steps from manual on how to do stemp plot box
To make a plot, first you will need to define a list. To do this, press "{", then enter the values of your list, separating each value with a comma, and ending the list with "}" then store (STO>) the list into a list variable ("2nd" + "1", "2", etc.). For a box plot, you will need only one list, and for a scatter plot, you will need two. One for the independent variable, and one for the response variable; that is, one for the X and Y axis, respectively. To make your plot, open the plot menu ("2nd" + "Y=") and select a plot. From there, you may select the type of plot and which lists to use as values.
To find the residuals for the line of best fit, from the home screen, press "STAT", then move one right to "CALC", then select option 4, "LinReg(ax+b)". Once this command is on your home screen, follow it with your X and Y axis lists, separated by a comma, eg: "LinReg(ax+b) L1, L2". Press enter. In a moment, you will be provided with 'a' and 'b' values. Plug those residuals into your "Y=" menu in the form "ax+b", replacing 'a' and 'b' with the residuals, and the line of best fit will be drawn across your graph.
Nov 11, 2009 | Texas Instruments TI-83 Plus Calculator
When I was trying to get residuals more apperaed
To turn on the residuals, you must turn diagnostics on.
Press 2nd then zero. You are now in an alphabetical catalog list. Go to the d's in the list highlight "diagnostic on" and press enter. This will take you back to the home screen. You must press enter and get the word "done" on the home screen.
If you are trying to get the residuals in a list, you must calculate a regression first. Then when you press 2nd stat, resid should be in that menu.
Sep 26, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
249 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
