Chaged oil 2 weeks ago sight glass is foggy some days psi gets stuck on 70 continues to run but pressure doesnht get up to 130 cycle off doesn't do it all the time or everyday it can run fine then act up . I added a little extra oil it seems to be running fine..
I am assuming the oil in the air filter, if its a beltless style would be to keep dust from going inside, like the really old cars were, they called them oil soaked filters. better at trapping dust and dirt.
Without more info or knowing your compressor my first question to you is,is the oil cooler clean and does the unit have good water flow. DO you have good water flow / pressure. The oil level should be about half way the sight glass running loaded. If the oil level was low ,when the thermostat opens it allows oil to flow to the cooler which lowers the oil level.Typical problems during this time of year are , , dirty oil cooler, Faulty thermostat, Faulty element temperature sensor, Low oil levels and bad oil. Also dirty oil filters restrict oil flow and can cause high element temp. problems. Try back flushing the water side of the oil cooler. Have you checked to make sure the water solenoid is opening. May have a bad coil or valve. May also have water solenoid plugged with something. What is the cooling water inlet temp and outlet temp. The W usually indicates water cooled. If not water cooled, most of the above also applies to air cooled units. just replace water with air if it fits.
